I am trying to convert a HD 720p video to a divx format, for a buddy of mine of a trip he took. He wants to play it on his Samsung 1080p DVD player without losing any quality. I tried using Divx Converter with the HD 720p mode, but when we try to play it. We get an error saying that the file is not supported.
Can someone please help us in solving this issue. Below is some information on the video information
Format: H.264/MPEG-4 AVC
Bitrate: 2043 kbps
Framerate: 23.976
Encoder: x264
Resolution: 720x400
Aspect Ratio: 1.800
Results 1 to 12 of 12
ffmpeg -i input.mp4 -vcodec mpeg4 -vtag divx -sameq -acodec libmp3lame -ab 192kb -ar 44100 -ac 2 output.avi
If that doesn't work, try adding -me_range 1023.
To download FFmpeg binaries go to http://ffmpeg.arrozcru.org/wiki/index.php?title=Links and take your pick. -
I am getting this error
Resampling with input channels greater than 2 unsupported.
Can not resample 6 channels @ 48000 Hz to 2 channels @ 44100 Hz -
In that case try AC3 to preserve all 6 channels:
ffmpeg -i input.mp4 -vcodec mpeg4 -vtag divx -sameq -acodec ac3 -ab 384kb -ar 48000 -ac 6 output.avi
I assume your audio is AAC since the video is AVC. If it is already AC3 you could use -acodec copy to leave it intact. -
that worked but, the file size went from 1.4 gig to over 5gig in size. Too large for a normal size DVD. Anyway to make it 4gig and keep quality?
It's very likely the audio... have you installed AC3filter on your system? Then you have the option to transcode the audio to AAC.
DivX Converter Audio Problems
By maccool111 in forum AudioReplies: 3Last Post: 28th Mar 2010, 03:47 -
Divx Converter
By jrodrigu123 in forum Video ConversionReplies: 2Last Post: 10th Dec 2009, 18:14 -
Problems w/ Divx Converter + Subtitles @ PS3
By RJARR in forum Video ConversionReplies: 7Last Post: 19th Aug 2009, 07:49 -
divx mobile converter
By sarmin in forum Portable VideoReplies: 1Last Post: 24th Mar 2008, 20:56 -
avi to DivX using divX converter pro
By Deaf Raiders in forum Video ConversionReplies: 3Last Post: 19th Dec 2007, 12:28
