  1. Hi all.
    Super quick question. I recently upgrade from Windows XP (SP3) to Win7 (all updates done).
    I use Dvd_Flick to convert my media into dvd format.
    On my same PC while I had WinXP, a 700mb media would only take 22-25 min max to complete.
    Now that I have Win7 as my OS, that same 700mb media is taking almost 1hr.
    Any idea why is that?
    Thanks all.
    Apr 2004
    Miskatonic U
    Your profile specs say OS X on old Mac hardware . . . . .
    32 or 64 bit ?
    Same drives ?
    Are the source and target on the same drives ?
    How much memory do you have ?
    Read my blog here.
  3. oh, that was my old computer. No more mac.
    I have a custom built.
    AMD 5700+
    2 gig ram (dc) XMS
    500gig sata HD
    550watt Corsair power supply
    9800gt video card.
    MY new os in win7 (32-bit)
    Thanks,
    Apr 2004
    Miskatonic U
    I haven't used DVD Flick on a W7 system yet. DVD Flick uses ffmpeg for encoding, so perhaps that version of ffmpeg isn't happy. You may have to wait for a new update with a newre version of ffmpeg to resolve it.
    I use AVStoDVD, which does pretty much everything DVD Flick does, and then some, and uses HCEnc for encoding. I have not noticed any significant change in rendering speeds for HCEnc on W7.
    Read my blog here.
