Hi!
I have a DVD Camera (Canon DC100) that I can record to small DVD-R disc. I also have the program Pinnacle Studio 9 for editing the video. Since Pinnacle Studio requires the movie to be in AVI format, I have tried convert my recorded movie to uncompressed AVI format using this guide: https://forum.videohelp.com/topic352376.html
My problem is that if I have recorded the movie in 16:9 on my videocamera, the XviD4PSP only allow me to use 1:333 (4:3) as output aspect.
If I check my source DVD video with MediaInfo I get this information:
General
Complete name : C:\Disc_31\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 11.1 MiB
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, Matrix : Default
Bit rate mode : Variable
Bit rate : 9 400 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : PAL
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.907
It says that the Display aspect ratio is 16:9
These are the settings I use in XviD4PSP:
Format: AVI DV PAL
Video Encoding: DV Video
I then select Video -->Resolution/Aspect...
These are the values that is preselected:
Input Resolution: 720x576
Output Resolution: 720x576
Input Aspect: 1.342 (1:1)
Output Aspect: 1.333 (4:3)
If I change the Input Aspect to 1.778 (16:9), I can't change the Output Aspect, as the only avaliable choice is 1.333 (4:3). This will resulting in black bars above and below my video, i.e the video is in 16:9, but with the black bars it will be in 4:3
I have then tried changing the format in XvD4PSP from AVI DV PAL to AVI
Then changed the encoding to: XviD HQ Ultra
Now the values that is preselected:
Output Aspect: 1.343 (4:3)
If I change the Input Aspect to 1.778 (16:9) the Output Aspect changes to 1.800 (1:1) with a output resolution of 720x400
I can also change the output Aspect Ratio to 1.778 (16:9) and keep the Input Aspect Ratio to 1.342 (1:1), but the output resolution is still 720x400.
Maybe I haven't understand everything about the Aspect Ratio, but is it possible to get 720x576 as output resolution and still have a Aspect Ratio of 16:9 ?
If the source video is in 4:3 I don't have any problems with using XviD4PSP.
If you need additional information in order to give me some hints of what I'm doing wrong, just ask me.
Kind Regards
Znooky
output for the avi should be set to 1024x576 (1:1) if the input is 720x576 (16/9)
(xvid4psp) Problem encoding with subtitles
By KgOlve in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 10:32 -
Aspect ratio slightly off? (Megui, Staxrip vs Xvid4PSP)
By ARTO65 in forum DVD RippingReplies: 24Last Post: 15th Jun 2011, 09:32 -
Xvid4PSP .mkv file opening problem
By hibbs in forum Video ConversionReplies: 2Last Post: 23rd Mar 2010, 18:56 -
Problem in Xvid4PSP
By maass in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2009, 09:11 -
Video/Audio synchronization problem with XviD4PSP
By pyromanic in forum Newbie / General discussionsReplies: 0Last Post: 30th Jan 2008, 19:40
