Is there an easy and fast way to take my MP4 and convert it to a divx avi and keep the quality from the MP4, so that I use on my usb stick for stand alone DVD/Divx player?
I use FFmpeg for that: ffmpeg -i input.mp4 -vcodec mpeg4 -vtag xvid -qscale 3.0 -flags +aic+mv4 -trellis 1 -mbd 2 -cmp 2 -subcmp 2 -g 250 -me_range 1023 -acodec libmp3lame -ab 192kb -ar 44100 -ac 2 output.avi
If the resolution is higher than your standalone will play (HD), add "-s 640x360" to resize it (16x9). If you really want identical quality, use -sameq instead of "-qscale 3.0," but -sameq is pretty slow.
EDIT: I figured out why -sameq was so slow for me - all the other encoding options should not be used with that option, it seems. When only -sameq use used, and the other flags and options are omitted, transcoding is fast. The resulting bitrate seems unnecessarily high to me, though.
DVD Player that plays Divx (.avi) and (.mp4) files ?
By keith knip in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 15:12 -
Blank video when converting MP4 to AVI DivX
By vidnov in forum ffmpegX general discussionReplies: 16Last Post: 12th Mar 2010, 18:45 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 18:51 -
HOW TO EDIT MPEG4 FILES IN (DIVX).AVI, .mkv and .mp4 Containers
By jhb50 in forum User guidesReplies: 0Last Post: 18th Jul 2009, 23:32 -
Divx to mp4. or avi. ?
By Dave135 in forum Portable VideoReplies: 4Last Post: 2nd Nov 2007, 04:02
