I had to re-encode some MPEG files to VCD compliant MPEG. The videos were out of sync so had to use TMPGENC to re-sync the mpeg. Then I used the Panasonic MPEG encoder to encode the re-synced MPEG to VCD compliant streaming MPEG. I watched both the original and VCD ready MPEG and didn't notice any difference.
Did I loose any quality in the process? Doesn't seem possible considering these are digital files.
I'm knew at the VCD game so, any info would be greatly appreciated!
Thanks!
I am having to re-encode xVCD for audio problems as well. I think that re-encoding does loose some quality. Its my opinion that the re-encoded xVCD's only look about 90% as good as the original. This could be because I am mad about having to re-encode so I am looking at the through angry eyes and there really is no difference in quality.
One of us should look at a few frames from our files both before and after re-encoding to see if there is a difference the same frame after the file has been re-encoded.
I'll let you know if I ever get around to examining my files frame by frame. -
I think you'll find that any time you re-compress, you lose some information. If it's not visible, who cares!
Converting HD Videos without significant quality loss
By kurian in forum Video ConversionReplies: 10Last Post: 10th Dec 2010, 09:37 -
avi to MPEG quality loss?
By prcole18 in forum Video ConversionReplies: 1Last Post: 7th Oct 2008, 10:38 -
converting vids w/o quality loss
By majax79 in forum EditingReplies: 3Last Post: 24th May 2008, 01:58 -
Quality loss in converting from DIVX to XVID?
By fwtong in forum DVD RippingReplies: 7Last Post: 25th Jan 2008, 17:37 -
Converting HD-DVD Rips to MP4 Without Quality Loss
By mpalm887 in forum DVD RippingReplies: 1Last Post: 10th Jan 2008, 11:14
