Hi, i have the JVC GY-HM100E that produce xdcam-ex .mp4 or .mov file. I need to play that file using a directshow based player.
I tried ffdshow with Haali or Gabest splitter. Using the first one, only the video is available. The second one, using graphedit, has the video and audio pin in output but the video play in a crazy way (using ffdshow uncompressed audio as decoder).
Here a video sample : http://www.sendspace.com/file/uq61j9
This is the video data taken from MediaInfo (v 0.7.24)
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Codec ID : 61
Duration : 12s 0ms
Bit rate mode : Variable
Bit rate : 34.0 Mbps
Nominal bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.656
Stream size : 228 MiB (96%)
Language : English
Encoded date : UTC 2009-11-12 11:36:07
Tagged date : UTC 2009-11-12 11:36:07
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Codec ID : twos
Duration : 56s 160ms
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 10.3 MiB (4%)
Language : English
Thx for any suggestion!!![]()
Results 1 to 1 of 1
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
Tracking problem with JVC camcorder.
By The-Geek in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2010, 11:23 -
JVC GY-HM100 has a huge problem !
By Turmap in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Apr 2010, 12:31 -
problem recording with jvc dr-m10
By restauroman in forum RestorationReplies: 3Last Post: 28th Feb 2010, 11:47 -
JVC DR-MH50S Loading Problem
By munish1000 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 5th Feb 2009, 07:36
