Results 1 to 12 of 12
  1. Chicken McNewblet
    Sep 2009
    I've usually been capturing 16:9 video from my DV camera and when I use VDub to make it a flagged MPEG4 file, everything works fine. But for some reason, VDub absolutely REFUSES to render my 4:3 files correctly. They never end up 640x480, they're always slightly off. I'm rendering it for PC viewing so I don't want to leave it in its raw state.
    I've tried setting the DAR and the PAR as 4:3 but it never ends up right. I don't want to have to resize the image. Any ideas?
    Feb 2004
    Australia
    16:9 to 4:3 ... not without resize filter applied ... thou it may also point to possible issue with system decoders or camera itself ... vdub can only do so much with the source file
    Slightly off is also covered by decoder / camera issues ... resize / crop to correct
    Flagging ... nope ... but try MPEG4 Modifier to correct ... also Enosoft DV Processor
    When in doubt ... resize / crop ... cannot be avoided
  3. VirtualDub resize filters work exactly as they should. You are simply doing something wrong. Describe your source and your process.
  4. Chicken McNewblet
    Sep 2009
    I'm not trying to make a 4:3 out of a 16:9, I'm trying to make DV 4:3 video (720x480, obviously) turn out correctly. I was under the impression that I wouldn't HAVE to do any resizing since it's just a simple 4:3 video...
    I import it into VDub, then do a Yadif deinterlace with the doubled framerate, then exporting with MPEG4 compression with either a DAR of 4:3 or a PAR of 4:3 (which both don't work). Are the flags just being ignored or something?
    When I do this exact process with 16:9 files, everything's fine.
    Jul 2009
    Spain
    What do you actually get as your output file?
    Post a GSpot or MediaInfo screenshot.
  6. Originally Posted by CursedLemon
    720/480 = 3/2, not 4/3. VirtualDub will show you a 3:2 image because it doesn't scale for PAR/DAR (unless you force the windows to a particular PAR/DAR).
    Keep in mind that the AVI container doesn't really support aspect ratios. Some codecs include aspect ratios in their private data but not all programs know how to get at this information.
    What codec are you using? Xvid? Most media players can see the Xvid PAR/DAR flags and will obey them. This can be effected by what AVI file reader, AVI splitter, Xvid decoder, and output renderer you have installed. But if your process works for 16:9 it should also work for 4:3. How far off is your result?
  7. Chicken McNewblet
    Sep 2009
    The original DV capture:
    General
    Complete name                    : F:\FF Vids\DV CUT\FF1\The Strangling Ritual\3 buddhastatue.avi
    Format                           : AVI
    Format/Info                      : Audio Video Interleave
    File size                        : 48.7 MiB
    Duration                         : 13s 714ms
    Overall bit rate                 : 29.8 Mbps
    Recorded date                    : 2009-04-10 13:49:14
    Writing library                  : VirtualDub build 32593/release
    Video
    Format                           : Digital Video
    Codec ID                         : dvsd
    Codec ID/Hint                    : Sony
    Duration                         : 13s 713ms
    Bit rate                         : 28.8 Mbps
    Width                            : 720 pixels
    Height                           : 480 pixels
    Display aspect ratio             : 1.500
    Original display aspect ratio    : 4:3
    Frame rate mode                  : Constant
    Frame rate                       : 29.970 fps
    Standard                         : NTSC
    Resolution                       : 24 bits
    Colorimetry                      : 4:1:1
    Scan type                        : Interlaced
    Bits/(Pixel*Frame)               : 2.778
    Stream size                      : 47.0 MiB (97%)
    Audio
    Format                           : PCM
    Format settings, Endianness      : Little
    Format settings, Sign            : Unsigned
    Codec ID                         : 1
    Codec ID/Hint                    : Microsoft
    Bit rate mode                    : Constant
    Bit rate                         : 1 024 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 32.0 KHz
    Resolution                       : 16 bits
    Stream size                      : 1.67 MiB (3%)
    Interleave, duration             : 34 ms (1.03 video frame)
    Interleave, preload duration     : 500 ms
    The new file exported from VDub after a Yadif double-framerate deinterlace and Xvid MPEG4 compression with the DAR set to 4:3:
    General
    Complete name                    : C:\Users\Cursed Lemon\Desktop\buddhastatue.avi
    Format                           : AVI
    File size                        : 13.3 MiB
    Overall bit rate                 : 8 146 Kbps
    Video
    Format                           : MPEG-4 Visual
    Format profile                   : AdvancedSimple@L5
    Format settings, BVOP            : Yes
    Format settings, QPel            : No
    Format settings, GMC             : No warppoints
    Format settings, Matrix          : Default (H.263)
    Muxing mode                      : Packed bitstream
    Codec ID                         : XVID
    Codec ID/Hint                    : XviD
    Bit rate                         : 7 093 Kbps
    Width                            : 720 pixels
    Height                           : 480 pixels
    Display aspect ratio             : 4:3
    Frame rate                       : 59.940 fps
    Standard                         : NTSC
    Colorimetry                      : 4:2:0
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.342
    Stream size                      : 11.6 MiB (87%)
    Writing library                  : XviD 1.2.1 (UTC 2008-12-04)
    Audio
    Format                           : PCM
    Codec ID                         : 1
    Stream size                      : 1.67 MiB (13%)
    Interleave, duration             : 17 ms (1.04 video frame)
  8. It should appear with the 4:3 AR in most media players e.g. mpchc, kmplayer, vlc etc... are you saying this is not the case? What are you using to view them?
  9. Chicken McNewblet
    Sep 2009
    VLC. It's what I use to "check" my files.
    The file ends up as, like...720x540. Which I now suddenly realize is 4:3 except upsized.
  10. What does it display as?
    Note some media players will display 4:3 NTSC as 720x540 instead of 640x480, but the AR is the same
    What happens if you use another media player to check? I think KMplayer plays most 4:3 NTSC as 640x480 instead of 720x540, so if it bothers you that much, you can try that.
    You could also remux into mkv and set the flag with mkvmerge, but your current video should display AR normally
  11. Chicken McNewblet
    Sep 2009
    Media Player Classic seems to get it to a 640x480 file.
    Hm.
  12. Originally Posted by CursedLemon
    No. The file is still the same 720x480. To adjust the aspect ratio FOR DISPLAY some players upscale, some downscale. It doesn't matter which.
