Does anyone have a recommendation for a bittorrent client on a Win 7 64 bit quad machine?
Are there any feeware ones which might take advantage of my new computer's capabilities over a 32 bit XP system?
Thanks!
The limiting factor with torrent clients will always be the network speed and any PC made in the last 5 years will easily keep up with the fastest available connection speeds. Use whichever client you want, it won't give you any performance advantage.
Volunteer for https://www.computersforkids.org.uk/
Vobblanker works in Win 7 64 bit, 32 bit?
By redsandvb in forum Newbie / General discussionsReplies: 15Last Post: 15th Aug 2012, 15:12 -
Win 64 bit - Quicktime - Adobe 64 bit
By beavereater in forum ComputerReplies: 1Last Post: 7th Nov 2011, 09:18 -
32 bit software compatibility with 64 bit machine ?
By joecass in forum ComputerReplies: 6Last Post: 28th Aug 2011, 10:09 -
how to burn mkv to iso to dvd??? my quad core machine is down.. and i need
By landocass in forum Newbie / General discussionsReplies: 7Last Post: 26th Jan 2011, 02:49 -
New PC coming with 64 bit Vista but I think its a 32bit machine...problem?
By Rudyard in forum ComputerReplies: 10Last Post: 21st Jul 2008, 19:47
