So when I use PS3 Video 9 to convert .avi to .mp4, does this improve the quality if I use the 1080p profile or does it stay the same or get worse?
Any conversion will reduce the quality, as Baldrick mentions. You may be able to minimize the effect, and whether or not it's noticeable is in the eyes of the beholder, but you still lose quality when you reconvert.
If your AVI has a DivX/Xvid video stream and an MP3 audio stream (as I mentioned in your other thread), don't convert. The PS3 will play DivX/Xvid AVIs/.divx files, though you may need to update your PS3's firmware.If cameras add ten pounds, why would people want to eat them? -
At best it appears to stay the same (i.e., visually no different). At worst, you will see a difference, and perhaps a great difference.Originally Posted by stgdlf
You say nothing at all about your source. If you convert a crappy 700 MB downloaded AVI file and are expecting to get bluray quality 1080p then you are sadly deluded.
Given the PS3 can play many forms of AVI file natively, you should only re-encode when absolutely necessary.Read my blog here.
Tbc makes bad picture worse
By mammo1789 in forum RestorationReplies: 3Last Post: 19th Oct 2011, 20:46 -
Video quality on DVD is worse than of MP4 of the same videoclip
By soezkan in forum Authoring (DVD)Replies: 13Last Post: 7th Apr 2010, 16:30 -
Video quality worse after burning .srt subtitle into .avi file
By twenty in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 08:51 -
The JVC vcr TBC/DNR makes the picture worse. Why?
By KeepItSimple in forum DVD & Blu-ray RecordersReplies: 4Last Post: 8th Jan 2008, 02:12 -
Picture Quality Question on made DVD
By Superstar24 in forum Newbie / General discussionsReplies: 24Last Post: 26th May 2007, 01:35
