OK I have a question here.
Would it be easier to cut out the black and white bits of a film from the color parts.
Encode them and then put them back together with avisynth.
Or is there some script that allows each section be done all at once?
What's the reason for the question? Are you filtering the different parts differently?
But yes, you can encode the entire thing at once by dividing it into different parts within the script using the Trim command (as jagabo says).
A=Trim(aa,bb)#.Filter however you like here
B=Trim(bb+1,cc)#.Filter however you like here
C=Trim(cc+1,dd)#.Filter however you like here
A+B+C
http://avisynth.org/mediawiki/Trim -
Uh I tried it and man that was to much work.
Thank you once again -
Then open your script(s) in VirtualDub and use the mark-in and mark-out tools to mark sections and save them. Then join them all together With VirtualDub when you're done (via File -> Append AVI Segment).
Note that VirtualDubMod has the ability to export it's edit list as AviSynth Trim() commands. -
I'll play with a bit to see what i can do.
There are 19 switches in this thing and to make it worse it doesn't switch between the settings.
It fades (blends) from color to black and white and then back -
If what you want is to apply different filters to different parts of the video, you may find it easier to do in Avisynth using ApplyRange.
http://avisynth.org/mediawiki/ApplyRange
adding color to a black & white video/film
By monks19 in forum EditingReplies: 22Last Post: 16th May 2015, 11:03 -
color blotches in black and white encode
By craigarta in forum Video ConversionReplies: 27Last Post: 16th Nov 2009, 08:21 -
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 09:04 -
color tapes are showing as black and white
By mbermel88 in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2008, 15:04 -
Video Software- black and white with color question
By video_enthusiast07 in forum EditingReplies: 4Last Post: 20th Jul 2007, 01:15
