Hello there,
I just got my new camera and trying to convert mp4 files to flv so I can be able to upload it on my site.
For this job I am using replay converter 3, but when I play or uploading the converted video no sound plays at all on my both riva and site players.
What is wrong with my case? Is it a difference between the mp4 and flv sound that does not match?
You might try dropping the files into MediaInfo and see what specifications the audio and video are, both of the MP4 and the FLV and that may give you some information. The audio may be there, just in the wrong format for your players.
And also you might try Any Video Converter Free Version. It seems to do well with format conversions.
And welcome to our forums. -
Thanx a lot!
I first used that MediaInfo program that showed me that the audio is:
Format : MPEG Audio
Format profile : Version 1 / Layer 3
Duration : 1mn 15s
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
I converted the file again with Any Video Converter and gave this file:
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format_Settings_Mode : Joint stereo / MS Stereo
Duration : 1mn 15s
Bit rate mode : Variable
Bit rate : 65.4 Kbps
Stream size : 603 KiB (11%)
It is now playing with full audio!
I think something is wrong with replay converter that does not include the Format_Settings_Mode and Stream size to the convertion, so for me it is now useless...
What do you think of these formats that MediaInfo shows?
FLV to MP4 help
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2009, 10:37 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51 -
youtube FLV video with h264 (x264) and/or aac (mp4) audio
By wiseant in forum Video ConversionReplies: 1Last Post: 26th Oct 2007, 16:49 -
MP4 to FLV -- new problem, I think...
By effective.glissando in forum ffmpegX general discussionReplies: 1Last Post: 16th Aug 2007, 23:52 -
Audio out of sync with video: FLV > MP4 using ffdshow
By jk318 in forum Video ConversionReplies: 0Last Post: 16th Aug 2007, 21:07
