Is there a way to use a controller even if the game doesn't support the controller ?
Ohhhh!!!
I had this same problem not long ago.
I found this, Xpadder, http://xpadder.com/
Excellent program and free!!
I use it for the COD games with my wired XBOX 360 controller.
You just assign the buttons on the controller to the relevant "keyboard" keys for the game.
You can set it up for different games and save them as different profiles.
EDIT:
Hmmm... i see now it say's it cost's $9.99 for the latest version 5.6, but i know i got 5.3 for free from their site...
I was just going to DL the new version and noticed that.
I am going to have to investigate some more. -
On the site it says it is not freee where do I click to get the free version? That is the same controller I am trying to get to work my 360 usb controller.
Yep, i DLed 5.3 from softpedia for free.
http://www.softpedia.com/get/System/System-Miscellaneous/Xpadder.shtml -
Yep, posted the same time you didOriginally Posted by t_jay17
I found the newest version here for DL but it seems to be a bad link, maybe they had to pull the latest version because the author is now charging for it.
But 5.3 works great for me.
http://www.majorgeeks.com/download5282.html
Yep, at the bottom of the page
But like i said, i still use 5.3 and it works great.Xpadder is no longer freeware and still being developed. Visit author link to see the latest shareware version. -
Thanks at first it didn't work with windows 7 but when I set it to run in windows vista compatibility mode it worked thanks.
GameCube controllers - Anyone here have one or had one ?
By Noahtuck in forum Off topicReplies: 2Last Post: 24th Dec 2009, 07:23 -
Can you buy adpaters to use gamecube controllers on an xbox1?
By yoda313 in forum Off topicReplies: 11Last Post: 14th May 2009, 17:18 -
Multiple SATA controllers
By mysts in forum ComputerReplies: 3Last Post: 3rd Mar 2009, 04:41 -
Are rockband 1 controllers really guitar hero 4 compatible?-yes
By yoda313 in forum Off topicReplies: 0Last Post: 26th Oct 2008, 15:53 -
IDE Controllers - Do I have it Correctly
By mn072065 in forum ComputerReplies: 10Last Post: 9th May 2008, 22:13
