So I've been fooling around with my DV camera a lot, taking videos of me playing guitar as well as using it to capture footage from things like my video game consoles, and all that wonderful junk.
Upon advice from this forum, I've been using VDub to deinterlace with doubled framerate, and using MPEG4 compression in varying qualities to share the videos with other people. Aside from the aspect ratio complications for DV video being converted into a different format (it's like a damn nightmare for someone who doesn't know the ins and outs of the whole thing), the videos just don't compare at all to the quality of the original, which is kind of a stupidly obvious statement, but yeah...
Is there a format that VDub can recompress to that's better than MPEG4 that isn't, you know, straight uncompressed RGB?![]()
Also, another question, can VDub recompress DV video? I have captured DV videos that I'd like to trim the beginning and end off of.
Results 1 to 11 of 11
For just trimming the ends, use Direct Stream Copy mode and no re-encoding will take place. Very fast, and no quality hit.
As for smaller files . . . DV can be interesting to work with. You have to separate fields before resizing or you get artefacts. You have to stabilise the footage if you want lower bitrates or you get artefacts. It takes a little time and a bit or reading to get the hang of it.Read my blog here.
Thanks!
Can you show me where I can look to better understand how to handle DV video? I know each format is handled differently, and that DV is a strange sort all its own. -
If you're going to share with friends (where you can't control what player they're using and what settings are used in that player) you probably want to deinterlace too. Note, MPEG 4 defines two main compression standards, ASP (Xvid, Divx 6, etc) and AVC (h.264, x264, etc). The latter gives better compression.
Video -> Filters -> Add -> Deinterlace
or
Video -> Filters -> Add -> Bob Doubler
Some people may have problems playing 50 fps material. If you don't need the greater motion smoothness (and want smaller files) don't double the frame rate, use 25 fps. -
VirtualDub doesn't include any MPEG family compression codecs, you need to install them. Xvid codec (ASP) and X264vfw (AVC) are two good choices. ffdshow also includes both.
Super Easy Question about COMPRESSION USING ADOBE PREMIERE PRO CS5
By BronProductions in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2012, 18:48 -
sharing of screen by video and picture
By vikas2903 in forum EditingReplies: 3Last Post: 30th Oct 2008, 16:30 -
Easy way to know if someone else is sharing wireless connection?
By edong in forum ComputerReplies: 5Last Post: 18th Feb 2008, 19:37 -
Best MPEG4 compression codec?
By W_Eagle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jan 2008, 06:12 -
Sharing Video/Audio on our network
By racingintherain in forum ComputerReplies: 16Last Post: 9th Jul 2007, 09:04
