I dual boot xp and linux. I need backup software that will image my whole c drive including the linux partitions on it. I've tried macrium reflect since it says that it supports ext2. The backup went fine with the windows partition but failed as soon as it hit the linux partition.
So what's another option? I'm getting ready to try paragon next.
Also I'm trying to keep this as freeware. I don't mind paying but if I can get by with freeware then so much the better. I don't need a lot of bells and whistles. Just a full backup of a dual boot system.
Thanks for recommendations.
Donadagohvi (Cherokee for "Until we meet again")
Paragon free version would be my next recommendation. It's very good. Failing that you can try Clonezilla, which is Linux based and shouldn't have any issues. It is quite slow in my experience with it compared to Paragon and Macrium.
Okay. Thanks Poppa
Donadagohvi (Cherokee for "Until we meet again") -
Paragon worked great. Backed up entire hard drive including linux partitions by booting with the linux rescue cd and then running the backup.
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 01:06 -
ERD Commander and Boot Discs *SOLVED*
By hech54 in forum ComputerReplies: 18Last Post: 7th Jun 2010, 04:42 -
Hard disk damage or corrupt boot manager? [Solved]
By Sakuya in forum ComputerReplies: 15Last Post: 4th Jun 2010, 23:33 -
system on C: but boot on D: (fix needed)
By deejay.2001 in forum ComputerReplies: 6Last Post: 11th Apr 2010, 13:04 -
Creating a dual boot system...best way?
By sdsumike619 in forum ComputerReplies: 11Last Post: 14th Dec 2008, 11:30
