I don't know the technical name for what DVDShrink does, but it has an ability to make vobs smaller, without necessarily losing quality.
Do any of you know of a program which can do this on an straight mpg?
That is I have an mpeg, which i would like to keep as mpg, only smaller - and DVDShrink can't do this unless its a DVD and I don't want to have to author this mpeg into a DVD.
	[s:e3e14d7b4a]avidemux[/s:e3e14d7b4a] rejig [s:e3e14d7b4a]Rejig[/s:e3e14d7b4a] avidemuxOriginally Posted by jagaboOriginally Posted by AlanHK
 (I cleaned up the topic...well...I accidentally removed all posts and it's too much work to get them back. Please just skip the lose quality discussion as branch already knows that now. )
 I'm glad I'm not the only one that deleted a topic by accident. I switched the program names. Should be correct now. I switched the program names. Should be correct now.
 redwudz
	Solveig MPEG-2 Requantizer (free) is another one:
 http://www.solveigmm.com/?Downloads
 Here's an explanation of how compressed domain transcoders work:
 http://forum.doom9.org/showthread.php?&threadid=63587
 Transcoding removes DCT data and will degrade quality, no way around that. But it may not be noticeable if, after transcoding, there is sufficient remaining excess discrete cosine transform data (DCT), essentially error correction. Transcoding cannot remove any motion vector data. Therefore, a "talking heads" movie with little motion will have relatively more DCT data and less motion vector data than an "action" film, and will "compress" better.Pull! Bang! Darn!
	why stop using dvd shrink at all? If its removing protection then use dvd fab first to rip as is then shrink PAL/NTSC problem solver.
 USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  need help about ability support please read 1 by 1By nopice in forum Video ConversionReplies: 4Last Post: 18th Oct 2011, 08:03
  Need Help: Ability to record FM Radio And TV Channels at once.By ginetti in forum MediaReplies: 5Last Post: 1st Dec 2009, 18:46
  Feature: do we have the ability to D/L whole discussions ?By vhelp in forum FeedbackReplies: 2Last Post: 17th May 2009, 16:21
  Suddenly my DVDshrinks aren't reading on playersBy john mcmillan in forum DVD RippingReplies: 15Last Post: 23rd Oct 2008, 14:47
  Best HDD Recorder with DL recording abilityBy disco_al in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Nov 2007, 10:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
