using vista 64 bit
When using raid 5 with all three drives identical and one of the drives goes bad, how does one know which physical drive to replace?
The controller should have something to indicate that. It's going to be on the drive cage (if integrated), the controller itself, or in the software interface for the controller.
FB-DIMM are the real cause of global warming -
thanks for the reply rallynavvie
The controller screen does indicate which one is bad but how do you relate this to which drive in the bay? Substituting one drive at a time does not seem to be a good idea. -
What controller is it? The manual should state what the onboard LED indicators mean.
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 04:13 -
What do you guys think of this MB/CPU for a new system rebuild?
By scustalow in forum ComputerReplies: 4Last Post: 29th Nov 2007, 16:27 -
What to do with ISO, trying to rebuild it in DVD RB?
By willhenderson in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 06:02 -
Rebuild Chapters, New VM Commands
By joesphroth in forum Authoring (DVD)Replies: 6Last Post: 9th Nov 2007, 13:26 -
Extract content from damaged DVD and rebuild
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 21:47
