    Dec 2003
    I hope I'm posting this in the correct forum....
    I just purchased an Acer Revo AR1600, and instead of including restore DVDs in the package, the restore software is on a second (proprietary format) partition. Acer includes a utility to burn your own recovery CDs or DVDs. The problem is that this computer doesn't have a DVD burner and I don't have an external one to use.
    What I'd like to do is find some program that pretends to be a DVD burner but actually writes the data to a file on the hard drive, which I could then transfer to another PC to burn or create an ISO from the "virtual burner" using any myriad of tools. That ISO could of course be burned by another PC.
    Googling turned up quite a few programs ODD emulators, but I couldn't find one that emulates an actual DVD burner. Is there a tool for this? The Revo came with Windows XP Home SP3.
    Thanks for any help!
    (OK I realise this IS in the wrong forum, sorry, but rather than cross posting, I'll leave it here, hopefully I'll still get some help)
    Feb 2004
    Australia
    Only by external or via network shared resource (burner)
    I tried this with an acer laptop using the same application ... internal and external burners both popped open ... but the application simply done nothing when it came to the external drive ... just sat there ... hopefully acer has corrected this problem
    There is also Macrium Reflect free for home users
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Can you insert a USB thunb drive and "burn" to that?
    Is the partition accessible or readable by any other method?
    Dec 2003
    After a little more research, I found that Virtual CD has a virtual burner. Can be used in demo mode so I was able to make the ISO's that I needed.
    Nov 2009
    One problem bugmen0t, Phantom.Burner.v2.0.0.0.Incl.Keymaker-EMBRACE inside the Rar file is warez.
