Hi, I've both real player & real alternative installed, but under real player the file won't play (rmvb files with chinese characters), and under MPC in real alternative the file play but no sound? Any help pls? thx
have had problems in the past with both real player and real alternative installed. Uninstall both, install just one of them and check.
install latest version -
You need to check each players subtitle support options and change font to @Arial Unicode MS , chinese_big5
Rmvb dose not support subtitles ... unless some fool used rmvb subtitle muxer
Stick with real alternative but never install both real players.
Media player classic and homecinema, vlc are independant players which should not cause issues -
Do you mean subtitles embedded in a RealMedia container are just an "ugly hack" ?Originally Posted by Bjs
Also, was RealMediaSplitter designed for supporting such "unofficial hack"?
I ask this because the ASF specs, for example, do allow subtitle streams in the ASF container
(no, I'm not talking about "script commands"),
even though Microsoft itself has never cared about
adding support for them in Windows Media Player for instance. -
gabest's real media splitter was designed for subtitle as additional stream
the rmvb subtitle muxer (for srt only afaik) was designed to take advantage of that and it worked .
don't know if that function is available in the current real media splitter -
Hi, Many thx for the helpful replies. I have used vlc in the past (some few years ago) but it wasn't as well featured as today, thx from above reply I'm using it now and it solved all problems. Again going back a few years (lol), in the past when converting rmvb file to other source (xvid/divx) using the avisynth&virtualdub method - real alternative codec won't do the conversion, hence today I only installed official real player just for its codec, may be real alternative have changed since my last rmvb conversion?
Onto another subject pls, could anyone pls recommend me a freeware that remove 'dead' files (duplicate file that have 0byte size and won't delete) pls? thx
Chinese subtitles require Chinese font on the computer?
By Haopengyou in forum SubtitleReplies: 0Last Post: 24th Mar 2012, 12:04 -
Software to help me learn how to play the Chinese violin
By Haopengyou in forum ComputerReplies: 2Last Post: 18th Mar 2012, 06:47 -
Question about rendering of Chinese characters on websites
By jimdagys in forum ComputerReplies: 7Last Post: 30th Sep 2009, 09:06 -
HELP encoding vids to play on Chinese import MP4 player
By MajorSmith in forum Video ConversionReplies: 4Last Post: 15th Jul 2008, 13:19 -
Chinese MP4 player - all great except video play - help! Please!!
By ilovefilms in forum Video ConversionReplies: 8Last Post: 15th Mar 2008, 04:28
