Hi guys,
I am trying to convert a clip using Xvid4PSP in windows 7 64-bit. I can say it's terribly slow and i converted the same file in vista 32-bit much faster. anybody have any idea about this problem?
(by the way, i am using xvid)
thnks for ur help.
Results 1 to 17 of 17
Couldn't tell yah.
Don't know what your setup (computer) is. -
craigarta has no idea what kind of computer you're using (you haven't mentioned any of the specs here or filled them in in the Computer Details in your profile). There could be a bottleneck somewhere that's bogging down Xvid4PSP for you.
What kind of video are you attempting to convert, and to what format?If cameras add ten pounds, why would people want to eat them? -
I have reverted to 5.0.36 on my W7 machines because I have been getting consistent audio sync problems with mpeg-2 PS to MP4 (PS3 profile) conversions using 5.0.37 (official). I would not say that the conversions are any slower than when running under XP though (same system - dual boot)
Read my blog here.
I have a dual boot XP and Win7 and Win7 takes more than twice the time to encode vob to x.264 mkv files.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Yep Xvid4psp version 5.10.330.0 takes more then 7hr's for ONE mkv video to recode (mp4 to mkv wiht burned in subs).
Avidemux? nope not a solution at all, the thing crashes all the time just by looking at it.
So there's no such thing as a stable and fast converter??? Bouth look promising but one is too slooowwwww and the other is too buggy.
Looks i'm stopping converting, because to much different buggy tools to install ore way to slow, and to much time consuming that is can use in a better way then searching and trying to convert a descent backup.
Just making backups again from DVD to DVD, done in 20 minutes and it plays on every machine.
And back to Divx backups, because that works on every TV, DVD divx supported player with the original subs of the DVD movie (idx). No more time consuming converting idx subs to ass, ssa, srt and ho knows what else.
Why burned in subs you ask? Divx gives the subs like you play a DVD, good readable, no probs here.
MKV and MP4 bad support on TV for subtitles, only support text based an therefor on most players and TV's verry tiny to read.
Not for me but for older people to way small, and sometimes when you look at a movie with lots of snow in it, not readable at all.
So for me back to DVD's an Divx. All the rest is verry badley supported and a wast of time. -
And wy is it that these devolopers still staying in the win98 and xp age? Common we had vista, win7 and now win8 and soon win8.1. Why making tools where you have to downgrate your windows framework???
(Sorry for necro-threading.)
Many recent MKV files will crash Avidemux. One quick and painless way around this is to drag and drop the file into MKVToolNix's MKVmerge window, and output an identical MKV. This should take seconds. This file with an appended "(1)" in the filename should open up nicely in Avidemux. -
Your machine is running only with one core, as original factory default ?
...or is running with all the cores ?
My laptop W-7 x64 is running with 8.
Run > msconfig > Enter > Boot tab > Advanced Options > "Check" Number of Processors (choose the highest #) > OK > OK > Restart
Agree:
Drag & Drop is the best way to go with most programs, in stead of searching, etc. since it set the program to their best possible setting automatically.Last edited by DJ_ValBec; 14th Feb 2015 at 16:01.
Serious XviD4PSP AAC bug with 64 bit Windows 7
By mcquade181 in forum Video ConversionReplies: 2Last Post: 27th Nov 2011, 01:22 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Xvid4psp does not work on Windows 7 64 Bit version
By pectin232 in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 19:41 -
XVID4PSP 6.0 2-pass, and Windows 7 64-bit question.
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 25th Jul 2010, 10:46 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42
