Good Evening,
I was wondering if I could take a storebought VCD and go take the DAT file from the MPEGAV folder, extract it to my harddrive then use vcdgear to go from DAT-->MPG and burn that? Are storebought VCDs set up like that?
Results 1 to 12 of 12
Visit my webpage at:
http://leech.at/e-z-e -
I'm not sure about store bought vcd's, but for normal vcd's your going through one too many steps. I've copied the .dat file from a vcd and loaded it in the Nero VCD template many times with no problems. So, I guess just try it...copy .dat to hdd, try to load it in Nero VCD project, if that fails..may want to rename it to .mpg.
Yes. If tou drag the DAT file into Nero in VCD layout, it will burn.
My preferred option when working with DAT files is to use VCDGEAR to convert the DAT -> MPG (A few small differences) and go from there. -
So its that easy to do for sure? Storebought VCDs have the same layout as those burned in Nero? There aren't any copyright protections that are there on DVDs?
If i can do that that would be cool, but i was also interested in uploading them to my ftp after i buy them for my friends to download.
just drag and drop the dat file to a folder on your hdrive and rename the file extension from .dat to .mpg
its that easy -
allright guys. didnt realize it would be that easy! thanks for the help.
if u want it to be a true VCDCompliant MPEG you will have to convert that DAT file to MPEG via VCDGear. Simply renaming does work, however it is not a "true" MPEG file there. DATs from VCDs are MPEGs with special headers. so if u want to rename it, go ahead, but i personally take the 2 mins to convert it using VCDGear to keep it in its original form.
So to recap,
1. Buy the VCD
2. Open it :P
3. Put it in the CD drive and copy the DAT to harddrive.
4. Use VCDgear 2.0 to go from DAT->MPG
5. Burn MPG file with Nero 5.5+
6. Pop a cold beer and watch the best-quality possible of a VCD. -
if u just want to make an Identical 1:1 copy of the disc...Originally Posted by e-z-e
1. Buy the VCD
2. Open it :P
4. Put a blank CDR in the CDRW drive
5. Open either Nero or Adaptec and do a direct copy
(IMO heres the way i feel about Adaptec vs. Nero, Nero is great for VCD, while Adaptec is great for Audio (easier compliance and such), Photo, and Identical copies, then whicher is your cup of tea u can use for Data b/c both are about the same for data CDs, but thats just my opinion.) -
i have successfully made my vcd that i bought into an mpg file. when i ran the dat through vcdgear to make it into an mpg it corrected nearly 3000 errors. why are there so many errors in a mpg file from a cd that was bought? could it be because the version is vcd 1.1?
I need help with Karaoke DVD to Karaoke VCD(MPG)
By adrianneow in forum Newbie / General discussionsReplies: 1Last Post: 8th Jun 2011, 09:02 -
[FFMPEG -> VCD-MPG] How to push CBR?
By Gew in forum Newbie / General discussionsReplies: 4Last Post: 13th Apr 2009, 09:05 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 11:34
