Hi. I am wondering if anyone knows how to hack a toshiba sd490 eke. I tried the hack for an sd490 but I can't even find a menu that permits entering of any codes at all. Grateful for any suggestions.
Welcome to the forums. Unfortunately most DVD players available today can't be hacked. Maybe you will be lucky and someone will post a hack that works for you, but it could also be that your model is slightly different from the sd490 and that's why the hack doesn't work. Manufacturers make changes all the time that break hacks that worked in the past.
Hi tonynorge, did you manage to hack your toshiba sd490eke? I've got the same problem
tonynorge hasn't logged in since Nov. 13 (see his profile), so good luck with that question.
Hiya, thanks
I have returned the dvd player and will hopefully get a region free one instead...
Can anyone help me to hack Toshiba SD7300, please?
By wertiouy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Nov 2011, 13:45 -
Toshiba LCD/DVD Hack
By mebrat in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 09:55 -
Toshiba sd 7200 no sound after hack
By Godiva in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jan 2010, 16:11 -
Toshiba SD190 hack problem
By elaine1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jan 2010, 11:00 -
Hack needed for Toshiba SD-34VBSB
By shanti in forum DVD & Blu-ray PlayersReplies: 2Last Post: 16th May 2007, 13:21
