Results 1 to 18 of 18
  1. I have an Asus M4A78-EM motherboard and I would like to buy 4gb of memory
    I have two choices and I would like to know which one is better and why?
    Also, can both fit the specifications of my motherboard?
    1. Kingston 4GB PC6400 (800MHz) DDR2 CL5 ValueRAM (Kit of 2)
    2. Kingston 4GB PC6400 (800MHz) DDR2 CL6 ValueRAM (Kit of 2)
    One more thing, is it any difference if I buy 2 sticks of 2gb, Kingston 2GB PC6400 (800MHz) DDR2 CL6 ValueRAM?
    Thanks in advance!
    Jun 2004
    Victoria, Australia
    http://en.wikipedia.org/wiki/Memory_timings
    and I'd imagine 2 sticks marginally better than 1 as they can be used in dual-channel (interleaved) mode for slightly better performance
  3. Originally Posted by TJohns
    So you would probably go for the 2 sticks right?
  4. Member craigarta's Avatar
    Jun 2001
    Cascade Mountains
    Well it depends if you want ECC or non-ECC ram
    There is also this option as well from Crucial
    the CL5 is non-Ecc and the CL6 is
    But you would need 2 sticks according to Eggheads
    DDR2 1066*/800/667
    *Due to AMD CPU limitation, DDR2 1066 is supported by AM2+/AM3 CPU for one DIMM per channel only.
  5. Originally Posted by craigarta
    DDR2 1066*/800/667
    What's the difference between ECC and non-ECC?
    I want 800MHz not 1066
  6. Member craigarta's Avatar
    Jun 2001
    Cascade Mountains
    ECC memory is only really beneficial if you're going to be processing massive amounts of data (like a server does) and all data needs to be 100% accurate. ECC memory is not normally needed for home systems, but is commonly used in server computers.
    I realize that you want the 800, but I saw the other posts saying 1 stick.
  7. Originally Posted by craigarta
    Anyway, I think all 3 are quite the same, not much difference, so probably either one will be ok right?
  8. Member craigarta's Avatar
    Jun 2001
    Cascade Mountains
    The only other consideration is the price and the performance of the ram.
    Other than that not that I can see.
  9. Originally Posted by craigarta
    any experience with a-data memory?
  10. Video Restorer lordsmurf's Avatar
    I'm not a fan of A-Data anything.
    My A-Data 16GB CompactFlash is terrible.
  11. Originally Posted by lordsmurf
    In what way?
    How about Kingston?
    Aug 2006
    In general, all other things being equal, the lower the CAS latency (CL), the better. Assuming that both types of Kingston memory are on the tested memory list, get the one with the lower CL number. 2 sticks are better than one if your board supports dual-channel mode.
  13. Originally Posted by usually_quiet
    I think it does, because I've used 2 sticks before also.
    Here is a link with my motherboard: http://www.asus.com/product.aspx?P_ID=0KyowHKUFAQqH2DO
  14. Member classfour's Avatar
    The Heartland, United States
    www.oempcworld.com is where I source most of my RAM. Price is reasonable, shipping is cheap, and I've never bought a bad stick. Not as chancy as buying off ebay.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Dec 2004
    Atlanta, GA
    I've also got to recommend www.oempcworld.com for memory. Great prices and very, very good customer service. If you have any questions, they are more than happy to answer them for you.
    Aug 2006
    Looking at the link, it does support dual-channel mode, so 2 sticks are better than one.
    If you are not over-clocking, not doing a lot of video encoding, and not gaming for hours on end, Kingston Value RAM will most likely be OK. Otherwise, memory sticks with heat-spreaders would be preferable.
    I bought Kingston Value RAM DDR3 for a different motherboard. It does come with a limited lifetime guarantee in the US. I don't know what applies in Finland. (Well, I'm assuming "FI" stands for Finland rather than the Falkland Islands, which was the other location listed for the same letters.)
  17. Originally Posted by usually_quiet
    Yes, you are right, I am living in Finland. kingston memory has lifetime warranty, as I remeber. What does limited warranry means?
    Actually I think the ram is ok for me, I don't play games on pc and I don't use video processing software so value ram should be ok.
    It's good that my motherboard supports dual-chanell mode, then I will buy 2.
  18. Member
    Aug 2006
    What does limited warranry means?.
    "Limited" means that there are conditions placed on the warranty. Examples are: The waranty can't be transferred from the original purchaser. The warranty only covers failure due to manufacturing defects, not failure caused by improper use of the product or a natural disaster.
