Hey everyone,
I have been using the MP4 PSP AVC option on Xvid4psp converter all the time, but just recently I started converting a couple animes and now they keep saying unsupported data on the psp, is there any reason why it is not supported now? but it was working before?
I am using the version 50374 full, and I did not alter any of the settings, I have not recently updated the firmware either, it is still at 5.03. It has worked on a bunch of animes but it just didn't work on the latest few I converted.
Ok here are the two files that I converted.
dog,%20bullets,%20&%20carnage%20-%2001.txt This is the one that works perfectly.
ouran%20high%20school%20host%20club%20-%2001.txt This is the one that doesn't work.
Using the same converter at the same settings. -
Looking at your log files i believe the cause is the Format Profile. The file that works for you is set to Main and the one that does not is set to High. Try formatting it again with the Format profile set to Main. The resolution should not be an issue. As i too convert a lot of anime for my psp and not all can use the full 480x272 native resolution.
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
Extracting video data from PSP games
By Cyber Akuma in forum Video ConversionReplies: 0Last Post: 10th Jul 2009, 07:25 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 10:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 08:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 14:13
