Whats the best site for color plugins and how do i know what each one does to get that color video looking better ? I didn t see any difference when i used one that came with dub And i used dub on on 1.5 gig movie, the only problem is when i finished up i had that same movie on 30 gigs so what the heck did i miss their ! ? - thanks a bunch . .
A good filter site: http://www.thedeemon.com/VirtualDubFilters/
As mentioned, if you don't select a compression codec, VD will use the default RGB, which will give you huge files.
Ok i see a Compression Codec list i hope thats what you mean; which one do i chose i have no idea, i see 13 choices - then one use it a 1.5 gig video will stay 1.5 gig right should be any bigger ! ! right ! ? ? - thanks
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Vitual Dub
By Leftbehind in forum Video ConversionReplies: 9Last Post: 7th Jun 2009, 12:19 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 06:00
