Hi guys,
I use Xvid4PSP for converting my videos. The only problem i have with this application, is the final output file size issue. Is there anyway i can set the target file size? i can do this easily with GordionKnot, but it's an old application.
If the answer is no, can you please introduce me some application which is as advance as Xvid4PSP.
Thanks in advance.
Yep, click on the E-button under Video Encoding and change the encoding mode to 2-pass size and you can set the output file size easily.
Wow, thanks for your fast answer. It helped me a lot. Can i do the same for h264 codec?
There's nothing you can do encoding to XviD using XviD4PSP that you can't do using GKnot. And in some ways, GKnot is superior, such as its crop/resize ability using the D2V, or the compression test to help choose the resolution and file size. I use XviD4PSP for x264 encodes, though.Originally Posted by bugsboney
Issue with XviD_Encraw and encoding to achieve a target size
By onesikgypo in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 09:38 -
XviD4PSP - file size
By joepic in forum Video ConversionReplies: 2Last Post: 5th Dec 2009, 10:50 -
ffmpeg.exe - Target file size?
By Gew in forum Video ConversionReplies: 0Last Post: 25th Feb 2009, 14:46 -
can i fix the target file size in convertxtodvd?
By sumeshkri in forum Video ConversionReplies: 3Last Post: 31st Oct 2008, 02:59 -
ffmepg: aquiring target file size
By raschko in forum Video ConversionReplies: 2Last Post: 19th Nov 2007, 17:46
