    Nov 2009
    I have comcast and can record tv shows on DVR.
    Can I make a DVD on computer from that?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Capture off the S-Video or composite outputs.
    http://www.kiva.org/about
    Feb 2004
    Pleasant Hill, CA
    In addition to edDV's advice, if you have the right cable box you might be able to capture using the Firewire port on the box.
    See:
    http://replayguide.sourceforge.net/dct6412/index.html
    and
    http://www.avsforum.com/avs-vb/showthread.php?threadid=403695&referrerid=0
    for some info.
    (I've done this a few times in the past, but not recently, so I have no idea if this is still possible or not. And it may only be possible for some channels and not others. Trial and error, and YMMV apply here. )
