  1. Member Abas-Avara's Avatar
    Aug 2009
    Azerbaijan
    Hi,
    Since I have Windows 7 I use the latest Beta of Ati Tray Tools,
    But there is a problem, as you see in the screenshot below there isn't any display settings.
    Is this normal in the latest beta? I have also used another beta, one of the last ones wich was compataible with Win7. But again same story and same problem.
    The flag once raised will never fall!
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    What are you trying to do? You can set display size in Win7 controls.
    http://www.kiva.org/about
  3. Member Abas-Avara's Avatar
    Aug 2009
    Azerbaijan
    I want to use TV out (in clone mode, with full screen video on second monitor)
    The windows controls aren't good and Ati Control Panel also.
    Ati Tray Tools was the only tool that worked for me on XP SP3
  4. Member edDV's Avatar
    Mar 2004
    I don't have an ATI card under Win7 currently but I've made those settings in the Catalyst control panel.
  5. Member Abas-Avara's Avatar
    Aug 2009
    Azerbaijan
    I've tried it, but there are 2 problems.
    I'm in clone mode and have 2 displays, flatscreen (1680x1050) and TV (800x600)
    problem one is, my main monitor also changes to 800x600, I dont want that I want to change both to 1680x1050 (it must work I did it in XP).
    problem two, the video doesn't come to fullscreen on my TV. In the menu looking to the examples/pics I must have set up everything perfect but still it isn't working.
    In XP I could work with overlay, surfing on internet on flatscreen while VLC is on fullscreen on TV.
    I'm still trying with the control
    EDIT: In VLC I also can't choose Directx wallpaper (maybe this a sympthon of something not working properly)
