    Nov 2009
    ok i'm not really new but i'm new on here. how do u and what do you use to rip a karaoke cd????? and what do i use to put it on a cd as a karaoke cd???? free ones only. thanks
    any help on this please.
    thank you all that help.
  2. Member Cornucopia's Avatar
    Karoake CD can mean a number of different things - CD+G, VCD, Enhanced CD, or some Non-standard format.
    Look up what your disc is, and look up these terms, also look up some of my past posts on the subject, and tell us more about WHAT you've got, then we can give you some answers (e.g.: if it's #1 you have to use some specialized and out-of-date tools, if #2 you just convert to DVD or other format with lots of tools available here...)
    Feb 2004
    Australia
    Welcome slayer_of_all
    Think this should get you screaming along
    CD+G > burn > cdrwin
    KaraFun
    Karall
    audiograbber now supports CD+G ripping
    Burner supporting CD+G / dao96 ... if in doubt use imgburn and check drives capabilities
    Forum link with more info here on vcd / dvd ... dealing with video
    Alcohol 120% better at burning than nero when it comes to karaoke disc burning
    May sometime be included in imgburn as possible future feature
    or mp3+gToolz ... explains the other associated required files ... outcome is a bin image
    Might include AV Video Karaoke Maker
    In the mean time there's DART Karaoke Studio CD+G 1.4.9cdgp ... 30 day trial
    The eagles karaoke dvd is simply vocals squashed and text overlayed which is colored to indicate singing position and style ... pretty crappy job
    Nov 2009
    thanks that helped alot.
    Nov 2009
    is there a guide i can use for burning karaoke cds with alcohol 120%
    Feb 2004
    Australia
    Alcohol 120% should be straight forward
    Basic image burn guide here
    If using those tools which produce a bin image then imgburn can handle that
    Jan 2010
    I downloaded songs on Itunes and they are mp4a. If I want to create a karaoke of these songs with lyrics on screen, etc. what do I need? Is there any freeware or not-to-expensive software for this? Thanks! I am computer savvy, but don't know much about this stuff!
