hello,
i don't know in which forum to write this message, so forgive me if i am in the wrong place.
i have an LG LCD 42LH70YR. i am trying to set the refresh rate at 100HZ. but it's only giving me up
to 60HZ.
i have win7 64bit. and a ATI 4890 HD as a graphic card.
using monster HDMI cable.
does someone can point me to any diraction.. i really tried everything..
Thanks.
Results 1 to 23 of 23
100 LCD HDTVs generally do not accept 100 Hz input. They take 50 Hz input and double the rate to 100 internally.
ditto Jagabo.
Are you sending video or computer desktop from the 4890? Which interconnect?
For video, "PAL" standards are limited to 25i/25p fps or 50p fps. These get frame interpolated or frame repeated in the TV to 100Hz.
If you send the desktop at 60Hz, frame processing is done in the display card.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
hello edDV,
i am sending computer desktop + video from the 4890. the LCD is always connected to the computer
i know for a fact my model of the LCD can support 100HZ i DIDN'T just paid more $$$ in the store... trust me..
no matter what i do.. that stupid "refresh rate" will not go any further then 60HZ!!
what can i do ?? -
That's because your videocard won't allow it, as was mentioned the tv will if it gets a 50Hz signal(eg tuner,DVD player).Originally Posted by smounche
I personally think these 100,120,240Hz hdtv's are a gimmick because you can't get true 24p playback. LG calls 24p "Cinema Mode". -
The 100Hz TV expects interlace video at 25Hz (50 fields per sec) or progressive video at 50 frames per second. This would come from a TV tuner. The TV then interpolates to 100 frames per second.Originally Posted by smounche
If you send it 60Hz frame rate from the computer, it reverts to 60Hz LCD computer monitor mode.Recommends: Kiva.org - Loans that change lives.
you don't set the refresh rate of the tv to anything but standard 50 htz pal or 60hz in the u.s. the higher refresh rate is turned on by the tv circuitry when it sees motion and you have turned on ME/MC (motion estimation/motion compensation) or whatever the option is called for your set. it's not really 100mhz as it can't stay at that rate.
"PAL" lacks a direct 24p support mode. Either 24p gets converted to 25P or the TV processes in "NTSC" mode.Originally Posted by MOVIEGEEK
"NTSC" HDTVs process 24P in one of the following ways.
1. Extract 23.976p from inverse telecine. You can't watch 23.976p directly without serious flicker. The TV will usually frame repeat frames 2 then 3 to 59.94 fps display.
2. A 120Hz TV will frame repeat 23.976 5x to 119.88 fps. This eliminates the 23232323 motion judder of "60Hz" HDTV sets. Advanced modes interpolate rather than repeat the four missing frames.
3. A 240Hz TV will frame repeat 23.976 10x to 239.77 fps. Advanced modes interpolate rather than repeat the nine missing frames.
I can see the case for judder reduction at 120Hz but am unconvinced 240Hz has benefit for film source.
For 59.94 non-film source (480i, 480p, 1080i or 720p), 120Hz must fill in one missing frame, 240Hz must add three.Recommends: Kiva.org - Loans that change lives.
I agree and most of the reviews for 240Hz HDTV's say to disable it if you watch 24p DVD or Blu-ray.I can see the case for judder reduction at 120Hz but am unconvinced 240Hz has benefit for film source.
Yes I left out 24p or 23.976p direct Blu-Ray modes but they get processed in the same way as inverse telecine.Originally Posted by MOVIEGEEKRecommends: Kiva.org - Loans that change lives.
There are two reasons for this. First, many film fans actually like the inherent jerkiness of 24 fps film. They don't like seeing smooth motion because it reminds them of TV, or even real life. Second, the motion interpolation used to synthesize in-between frames often makes mistakes. This leads to obvious distortions in some material. You still want to use the non motion compensated 120/240 Hz feature to eliminate the 3:2 or 6:4 judder.Originally Posted by MOVIEGEEK
OP,
This thread might help: http://thegreenbutton.com/forums/p/73709/360982.aspx -
O.K
first thanks to everyone for replying..
so. i can't get it any more higher then what it is now? (60HZ) -
hmm..
i don't understand something..
i only play MKV files (720p & 1080p) and right now. when i go to the properties of "screen resolution" in win 7. it's on 1920 x 1080
and the refresh rate is 60HZ
why did i payed so much money on a flat screen that support 100HZ and true cinema 24P. and a very good graphic card (ATI HD 4890) ?? -
If your MKV files are 25 fps you'll probably get smoother playback at 50 Hz. Or 24 or 25 Hz.Originally Posted by smounche
Why didn't you do a little research first? Traditionally, computer and TV refresh rates don't match.Originally Posted by smounche -
it's just like all the other 100, 120, and 240 hz tv's, it only goes into that mode when it wants to, not something you can control, other than turning it off completely.
More to the point, they don't accept those refresh rates as inputs. Only output to the LCD panel.Originally Posted by aedipuss
Yes convert the video to a format the Samsung can decode (e.g. uncompressed 1920x1080i/25 HDMI or MPeg2 , see manual for list of formats) then the TV will process that to 100Hz. It will deal with any of the normal Blu-Ray player outputs (uncompressed 1080i/25, 1080p/24, 1080p/25, 720p/50...).Originally Posted by smounche
If you feed it a computer screen at 60Hz, the TV does nothing but emulate a computer monitor. The ATI card and/or software player are processing the video.Recommends: Kiva.org - Loans that change lives.
ahh.. i see...
so if i want to get the best quality. i need a good graphic card (like Nvidia GTX-295) ?
that card has pure HDMI input.. will i get better quality using that card ? -
No. That card will not be appreciably different from your ATI 4890.Originally Posted by smounche
Consider an external media player or a Blu-ray player. These will accept interlace or progressive video files and output uncompressed to the TV over HDMI.
HDCP error with philips HD LCD and DVD player
By fatboy78 in forum DVB / IPTVReplies: 28Last Post: 19th Jan 2011, 08:14 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 12th Feb 2009, 23:01 -
Phillips 5982 Error - Weird Characters on LCD
By kokaine in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Nov 2007, 13:58 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 12:29 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
