I have "The Usual Suspects" dvd that has the standard full screen version on one side of the dvd and a wide screen version on the other side. The tools I used are Smart Ripper, DVD2AVI, and TMPGenc. After encoding the full screen version both mpg's that I created are out of sync with the audio and video. This is the 1st time I have had this problem. Is it because of the DVD format? If so, how do I get around this problem?
Results 1 to 1 of 1
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 13:52 -
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 16:47 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 20:23 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 09:09 -
compareing 2 videos side by side in same video. (sugestions)
By tessa101 in forum EditingReplies: 4Last Post: 9th Jan 2009, 03:36
