I've got an interlaced MPEG TS, 1920x1080/29.97, and I want to deinterlace and double the frame rate (and convert to x264, but that part works). I run it through DGIndex, and in my avisynth script I've got mpeg2source("file") and tdeint(mode=1), and I open that in Virtualdub and save it. The resulting video is 59.94 fps but its in slow motion. Am I missing something obvious? Other bobber type deinterlacers have the same result.
If I haven't done anything dumb so far, here's a sample of what I'm working with.
http://www.mediafire.com/download.php?5jjmgg2dmcj
Might your CPU be too slow to play back the resulting file at full speed? Unlikely, but try resizing and test again
test.x264.avi"Quality is cool, but don't forget... Content is King!" -
That worked, you're the man. Thanks.
While this is here, would you recommend any specific deinterlacer for this?
Blu-Ray 1080i source > MKV, confused about deinterlacing
By Phat J in forum Video ConversionReplies: 0Last Post: 24th Aug 2011, 23:42 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
experienced user looking for avchd 1080i deinterlacing help from experts
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Aug 2010, 19:25 -
Can't figure what's wrong with this 1080i video
By adessio in forum Video ConversionReplies: 24Last Post: 28th Feb 2010, 20:23 -
Blackmagic Intensity Pro, 1080i video, and deinterlacing
By lbgaus in forum Capturing and VCRReplies: 0Last Post: 15th Sep 2009, 00:44
