Is there an easy to use program to cut/trim/edit .ts-files recorded on a Dreambox 8000? I want to cut unwanted parts of the ecording and keep the file as is. Or maybe also be able to convert it to DivX or something?
	I use ProjectX to demux TS files and then edit them with Mpeg2Schnitt before authoring to DVD Video (GUI for DVDAuthor) or converting to xvid (VirtualdubMod).
 There's a thread with further discussion here: http://club.myce.com/f34/how-do-i-edit-ts-file-207338/.
 Slainte
 middersVolunteer for https://www.computersforkids.org.uk/
	Hi nordic45,
 It all depends what is inside the .ts. Ideally you want a smart editor to edit your stream which will not re-encode everything.
 If it's H.264 then TSPE will edit it.
 If it's MPEG2 then TSPE and a whole load of other editors will be able to edit it to varying degrees of success.
 TSPE will let you know exactly what is inside the stream so from there you can make a decision on which editor to use if TSPE does not already meet your requirements.
 There are some freeware editors out there which you could try but it all depends on what is inside your .ts and how well the editor can handle the contents.
 Of course searching VideoHelp will help considerably!
 Regards,
 Vent
	I use the editing function within ProjectX to edit and demux in the same step and then author DVD with GUI for dvdauthor. This works with MPEG-2 ts files at standard resolution.Originally Posted by midders
  Which software to edit dreambox mpeg4 ts?By manutd in forum EditingReplies: 11Last Post: 3rd Jan 2012, 09:00
  Some simple questions about Dreambox and HTPCBy Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 12:44
  Dreambox Stream RecordingBy Max Wren in forum Video Streaming DownloadingReplies: 0Last Post: 1st Apr 2009, 10:28
  Transcode for DreamboxBy dreams in forum Video ConversionReplies: 4Last Post: 13th Oct 2008, 07:50
  870712 - xvid to dreamboxBy hamidi2 in forum Video ConversionReplies: 0Last Post: 3rd Oct 2008, 14:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
