Hey all,
so I have my friends laptop, which was bogged with viri, and i downloaded combofix to get rid of them. running combofix resulted in the message "a rootkit has been detected, windows will now restart" upon restart i get the following blue screen...
A problem has been detected and windows has been shut down to prevent damage to your computer
then some bs about restarting and scanning for viruses
says to run chkdsk /f to check for harddrive corruption, then technical information:
***STOP: 0x0000007B (0xF88DC524,0xC00000034,0x000000,0x000000)
safe mode, last good, windows recovery console all result in this screen. any ideas? im desperate as i dont want to give this friends computer back worse off then it was (cant even boot into windows now)
edit: the computer is a windows XP if that matters
if you can boot a window xp cd you might be able to try the recovery console. maybe try fixmbr and/or chkdsk /f. if the mbr was damaged the drive won't boot. if that doesn't help maybe try to do a repair install. and next time don't use combofix. it's not meant for the average person and there are warnings about this type of problem everywhere you can download it. and still people run it...
I know what caused this. Combofix detected a false-positive which was a critical system file to windows, you need a system restore, aedipuss is right, dont use combofix, but hitman pro
Only repair install or where this fails, clean reinstall
It may not have been a false positive detected ... only someone with experience and having access to the affected system would be able to know with any accuracy
Use a bootable linux to recover and backup user files -
"Viri" is NOT the correct plural for "virus" in English. It's "viruses". SeeOriginally Posted by gooberguy
http://en.wikipedia.org/wiki/Plural_form_of_words_ending_in_-us
for an explanation. There's also an explanation of the correct plural of "octopus" which is not "octopi" as some think.
I apologize for the grammar lesson, but I don't like seeing the incorrect "i" plural that many use. -
According to my dictionary, octopusi is an acceptable alternate to octopuses, and I suspect some modern dictionaries say similarly for viri. However I prefer it as in the James Bond movie, octopussy. So is the plural of mouse mouses or mice?Originally Posted by jman98
Being curious, I decided to look. Both Dictionary.com and M-W.com (Merriam Webster) show the plural as "viruses" and have no entry for "virii" or "viri".Originally Posted by JohnnyBob
(Not that I didn't trust Wikipedia....
Windows has detected a problem and is shutting down . . .
By Seeker47 in forum ComputerReplies: 20Last Post: 9th Jan 2012, 21:30 -
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 15:14 -
Problem converting .ts file - no video (only audio) detected!
By guy24s in forum Video ConversionReplies: 2Last Post: 29th Aug 2011, 19:57 -
avisynth error: 64-bit windows not detected
By adom in forum EditingReplies: 10Last Post: 20th Mar 2011, 07:35 -
JVC DV Camera Not Detected in Windows XP
By Mark97213 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Jun 2010, 12:22
