hi there,
when i want to open and convert a videostream (RTMP) with VLC 1.0.3 (latest version), the conversion process stops within a few minutes, so i end up with a partly downloaded (and converted) file.
what i select in VLC:
1) Media --> Convert/Save --> Network
2) Protocol: RTMP
3) Address: rtmp://edge02.fms.dutchview.nl:1935/hetgesprek/20080516160000AMS_2_1_1311
4) click Convert/Save
5) Destination file: C:\directory\filename.asf
6) Profile: Video - WMV + WMA (ASF)
7) check Dump raw input
i tried different output settings besides ASF and WMV, and also the "Stream Output way" (which has slightly different output options), but it abruptly ends everytime. any ideas?
if not; any idea on other program(s) to save this flash videostream as lossless/uncompressed as possible, or to .asf or .avi directly (vixy.net didn't work)?
link to video online: http://www.hetgesprek.nl/archief/1105/
link to put in media player (URL): rtmp://edge02.fms.dutchview.nl:1935/hetgesprek/20080516160000AMS_2_1_1311
Try video downloadhelper for firefox or orbit downloader.
Or the old good rtmpdump, run from a command line prompt with just
and you will get the video in an video.flv, no conversion.Code:rtmpdump -r rtmp://edge02.fms.dutchview.nl:1935/hetgesprek/20080516160000AMS_2_1_1311 -o video.flv
before i'm using video downloadhelper or rtmpdump, can you tell me if they will give me a flash file of higher quality than orbit downloader (which i've already tried)?
Hello,
this thread has been somewhat helpful, thank you! I have a related question:
I've been able to locate the rtmp URL for the streams in Swedish internet broadcasts of state television. I wish to watch these streams on Xbox/XBMC. XBMC does not support rmtp streams as such, which is why I want to re-code it to an mms/asf stream, for example.
There is a XBMC script available for viewing the Swedish internet television, but this doesn't cover the live broadcasts, which is what I'm trying to get to work.
I am able to re-broadcast mms streams without any problems.
As far as I've understood, my best shot is to re-broadcast the stream with VLC. The RTMP stream plays without error if I just use "Open network stream" (or whatever it's called in the English version) in VLC 1.03. But when I try to stream it, VLC crashes with no error message. Does anyone know why?
Is it supposed to be possible to re-broadcast rtmp streams at all, and what can I do to make this happen?
Stream Recording with VLC - Black frames problem
By Kittciokas in forum Video Streaming DownloadingReplies: 6Last Post: 7th Aug 2011, 09:38 -
How to download a rtmp stream from a website
By krb214 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Jul 2011, 19:08 -
POP-up rtmp stream riping?
By shorto in forum Video Streaming DownloadingReplies: 4Last Post: 9th Aug 2010, 09:48 -
How to stream using VLC
By dafodill in forum Software PlayingReplies: 4Last Post: 29th Jun 2010, 18:23 -
Saving incoming video stream using VLC 1.0.1
By CKQueen in forum Video Streaming DownloadingReplies: 2Last Post: 10th Aug 2009, 07:51
