I have a TV show recorded from sat. It is in an MPEG TS container. containing an MPEG-2 video stream, and a MP2 192k audio stream. That sounds perfect for remastering to DVD using ffmpeg and copy.
My problem is, that I have holes in the sound. 100 breaks are detected in MPEG Streamclip (I am a Mac user btw). So when I treat the 2 streams individually, the sound file ends up being 6 seconds shorter than the video, getting all out of sync.
If I play the original TS in VLC, all plays fine, and sound /video is synced. If I export it as DV from MPEG Streamclip (thus causing recompression), all is fine.
But ffmpeg never resyncs the sound again after the holes. Is there any way I can force it to do so ? Like "keyframes" that is used to re-sync audio and video ? I want this without recompression, as it works fine if I recompress and thus changes quality.
Should I use another tool ? Maybe use VLC to transcode sound only and remux that version, hoping it will be of correct length ?
Now that I have more terrestial DVB-T MPEG2 and H.264 channels (including HD), I am expecting I might see more dropouts, so I want a workflow that can handle that.
lossless (or minimum loss) flv video conversion
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2012, 07:59 -
VHS to DVD (editting or lossless conversion?)
By fvnesscafe in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 23:37 -
Lossless Video Formats / Conversion
By mltwitz in forum Video ConversionReplies: 1Last Post: 13th Aug 2010, 15:57 -
Easiest lossless AVCHD splitter with no conversion
By marcolisi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 5th May 2010, 22:04 -
lossless conversion to alternate containers
By krohm in forum Video ConversionReplies: 33Last Post: 12th Jun 2009, 04:19
