Hi guys
I have downloaded several Fitness Dance videos off of Youtube using zamzar, and would like to put them on a DVD so i can watch it on my dvd player.
My question is, will the 3gp format videos burnt on to a dvd play in a dvd player?
Also, do i need a special program to burn it on to the dvd?
Thank you
Hello this is IT, Have you tried turning it off and on again??
No.
Convert to DVD-Video format.
Check this post out: http://www.digitalfaq.com/forum/showpost.php?p=8437&postcount=10
You need VirtualDub, a few plugins/filters for it -- all free.
Then export to AVI, or frameserve out
Convert to MPEG
Author to DVD, burn.
There may be some crappy "all in one" program, but quality generally suffers. It will look really bad without some standard attention in VirtualDub, bit of filtering.Want my help? Ask here! (not via PM!)
cool thanks heaps!!
Hello this is IT, Have you tried turning it off and on again?? -
You can use Zamzar to download and convert Youtube videos directly to avi. Then burn the avi file to a CD or DVD. Most newer DVD players will play avi. Or just copy the avi to your USB memory stick if your DVD player has the USB jack. I have a cheap DVD player with USB jack I'll give to you for free, but you have to come to China to get it. Bought it at Walmart for $18 and it lasted a year before the spindle motor power supply electronics broke. USB jack still works though.
Avidemux & Conversion Issues with Sony MTS Format
By callmebc in forum Video ConversionReplies: 24Last Post: 11th Mar 2012, 12:42 -
Issues with Proper Format for DVD
By hughgogirl in forum Video ConversionReplies: 4Last Post: 29th Dec 2009, 19:20 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
File format issues
By ziggy1971 in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2008, 12:28 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
