I have a .mkv file containing the following
video: dx50
audio1: mpeg4 6 channel
audio2: 2.0 ogg vorbis 2 channel
subs
I'm trying to remove the subs and the mpeg4 audio track from the file and output into a new .mkv file
I need to remove the mpeg4 primary audio and the subs track so that I can do a good conversion to iPod sized mp4
Near the end of the splitting process using AVI Mux, the program crashes and the entire file that it had output is useless and wont play in VLC player
I have isolated the problem to the 2.0 ogg vorbis 2 channel audio by running a test of just splitting out the audio
does anyone know how to fix this corrupted audio file so that i can complete the conversion?
the host file audio and video plays back in VLC player just fine and it's not the program since this is the last of 26 files that it worked with and the crash was repeated in avidemux 2.5 when i selected which audio file i wanted
Try using MKVtoolnix. It has a command line tool mkvextract which would have this syntax
mkvextract tracks C:\input.file.mkv 01:C:\video.h264 02:C:\audio.aac
Where 01 is the first stream, 02 the second, and so on.
If you would rather have a GUI - MKVEXtractGUI is available.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
after a little bit of tinkering i was able to do it.
had to convert the ogg file that it spit out to a mp3 though to get it to work the new mp3 did not continue the corruption
thanks alot!
About MKV to AVi audio(Vorbis) Sync Problem
By afcoff in forum Video ConversionReplies: 0Last Post: 4th Feb 2009, 11:38 -
DVD to H264 with Triple Audio (Vorbis) - results only in lag when playing
By Dannyramsnes in forum DVD RippingReplies: 9Last Post: 8th Sep 2008, 11:31 -
Help converting with mkv2vob: Error is Unsupported Audio Codec: VORBIS
By rjsax21 in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 23:54 -
AVI with Vorbis audio
By cheerful in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 19:46 -
VirtualdubMod: DivX and vorbis aduio -- result file has no audio
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2007, 02:27
