smile..hey guys![]()
yeah my question might be very stupid.
but seriously i have no idea were to ask..
anyway my question is.. on many sites (torrent) you see these tv series uploaded in .avi extention.
and in the file name there is allways written HDTV.. so my question is how do people record these in .avi?
if i want to buy such a recorder what is it called? and what do i have to look for?
so the question is.. these .avi files i see, are they really recorded with a recorder or are they converted?
i hope i make sense.. my english i bad..
i hope someone can help me out, and guide me..![]()
They are probably recorded using a hd digital device for your computer like https://www.videohelp.com/capturecards?CaptureCard=&hdtv=1&searchconnection=Any&price=&...&Search=Search . But that requires that you have hd channels that works for that digital device, lots of hd channels requires special boxes that records in a encrypted format.
Since these are all encoded to xvid that means they were all recoded for smaller size.Originally Posted by angles
"Recording" off a digital on-air broadcast with a computer tuner is similar to a stream capture. You are just capturing what they are transmitting (e.g. MPeg2 or h.264). Often cable or sat transmissions are encrypted so other means are used to "record".Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks for the fast reply guys
but what about a standalone recorder. withouth a need of a computer?
what does a dvd recorder do exacly? does it records into a .avi or other extention format?
and do such things as portable recorder exisit for the tv?
i know this sandisk vmate memry card recorder.. it records in .mp4 but quality is not so great. -
You can get DVD recorders with digital (DVB in your case) tuners. DVD will be SD though.Originally Posted by angles
You can get TIVO type DVRs with local on-air tuners or you can rent similar models from cable or sat companies.
Direct capture of uncompressed HD requires a sophisticated computer solution or pro level gear.Recommends: Kiva.org - Loans that change lives.
Need some help on DVD to Avi for HDTV
By Tommy-T in forum Video ConversionReplies: 14Last Post: 14th Jul 2011, 04:40 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 15:55 -
HDTV to MP4 or AVI
By onlinevic in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 13:25 -
watching avi from my pc to toshiba lcd hdtv
By goo2 in forum Software PlayingReplies: 6Last Post: 21st May 2008, 21:19 -
HDTV AVI aspect ratio
By cheerful in forum Software PlayingReplies: 21Last Post: 5th May 2007, 19:47
