Greetings,
I'm new to the VCD capture, and I was wondering if anyone has had any success with using Virtual Dub or other software besides the ATI MMC 7.1? If so what version of drivers are you using? If I attempt to use any other program for capture besides the MMC, I get a capture device driver error. The ATI MMC capture works pretty good, but I'd like to be able to use other programs.
I'm running the MMC 7.1, Direct X 8.x, and the ATI Rage 128 4.13.7078. I've uninstalled and reinstalled everything, but I get the same message. Any help would be appreciated. Thanks!
Check out this link to get some help http://www.vcdhelp.com/phpBB/viewtopic.php?topic=50143&forum=2&7 I installed the wrapper and updated my drivers to the beta version http://support.ati.com/drivers/winme/winme_radeon_4137115_sp.html and I was able to use Virtual Dub with no problems.
use drivers 4.12.6292 and you'll have real vfw support and other programs will work in addition to MMC. i wrote a long, step-by-step of how to do this for someone last week on winME:
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=50769&forum=2
search the forums for and i think you'll find more about ATI and MMC and drivers. basically to get the best compatibility and the most out of MMC 6.3 and 7.1, you need to install both a couple times. but the vfw capture driver comes as part of MMC 6.3 i think, so you at least need to install it once even if you won't be using it. -
Thanks for the links and tips everyone! I'll try it out.
<font size=-1>[ This Message was edited by: mcgraham89 on 2001-07-24 11:41:20 ]</font>
How 2 Capture HD with ATI HDTV Wonder
By NautTboy in forum DVB / IPTVReplies: 41Last Post: 2nd Apr 2010, 13:38 -
Resolution Test - BT878 - ATI Rage Theatre - Philips SAA7130
By BrainStorm69 in forum Capturing and VCRReplies: 3Last Post: 23rd Mar 2010, 07:10 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Didn't ATI All in Wonder 128 Pro have Mpeg capture?
By Ensign in forum Capturing and VCRReplies: 7Last Post: 7th Mar 2008, 10:13
