Hi...
How to put some specifical signs because ( in my language) we use some specifical word signals, likeusing Credit Roll, from Sony Vegas?~
---> https://www.videohelp.com/tools/Vegas
Do I need to set any configuration from the program? Or specify something on my keyboard or something?
Thanks.
Results 1 to 10 of 10
This question would likely be better answered in our Editing Forum. Moving you.
If not that, you could always try either using the "ALT+NumPad####" code method. You can sometimes see what the code is by using the stock Windows CharacterMap app. For example,
EqualsCode:ALT + 0169
If you can't cut & paste from MS Word into Vegas' titler (like MOVIEGEEK was saying), I'd be very surprised.Code:©
Failsafe fallback would be creating what you want in Word and doing a Printscreen / Screencap, and adding the graphic in Vegas. But I'm sure you'll have better options than that.
Scott -
Hello, dear all.
Thanks for the aswers.
I'll try your advices.
I need to know how to put some signals, like:"ALT+NumPad####" code method.
^ ~ ` ´ ª º ¬ § {
Among others...
And even musical notation too.
Does exist some charts, tables or "code tables" which I can consult?
If you know some of them, please, point them.
Thanks again for your help. :P
Best regards.
devil (johner) -
I'll try these ones above:
---> http://unicode.org/charts/
---> http://wareseeker.com/free-unicode-character-map/
---> http://mac.softpedia.com/get/Utilities/Character-Map.shtml
---> http://tlt.its.psu.edu/suggestions/international/accents/codealt.html
---> http://desktoppub.about.com/cs/fontsoftware/ht/character_map.htm
---> http://en.wikipedia.org/wiki/Character_Map ( explanation about the subject)
---> http://tlt.its.psu.edu/suggestions/international/accents/charmap.html
---> http://www.ehow.com/how_2267577_use-windows-character-map.html
---> http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/app_charmap.mspx
And, if I need to type any specifical musical notation? How can I discover a "CharacterMap code" for it? Are there any specifical code for them?
If you have some more tips, please, post it. :P
Thanks.
Best regards.
devil (johner) -
Download the musisync font then drag the .ttf file into the WINDOWS\Fonts folder, you can then insert musical characters into any program.
musisync.zip
You can also write music with the Lassus font:
http://www.dafont.com/lassus.font -
those should already be in webdings or wingdings that comes with windows OS (including the treble and bass clef)
simply call on them via alt + keypad
start>all programs>accessories>system tools>charactermap
if you don't find them, perhaps they weren't installed -
Can't you install language packs and access them though the language toolbar in windows? Once installed , I think you should be able to access special characters from whatever language
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
How to put 640x480 video in 1280x720 frame in Sony Vegas Movie Studio?
By vid83 in forum EditingReplies: 6Last Post: 10th Feb 2011, 23:47 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
