I've done a lot of searching and have not found an answer to this. If I have overlooked it, then I apologize.
I'm converting my copy of GI Joe to AVC to play on my 5.5G iPod. In the AVS Script Creator I have to use 1.77 NTSC as my input DAR. I auto crop to 0, 60, 0, -66. I check resize and change it to 640. I check the clever anamorphic box and set it to resize to mod16. The suggest resolution (mod16) box now automatically checks and the grayed out box says 320. If I now encode the video, all will work correctly.
My question is this. Is it ok to uncheck the suggest resolution (mod16) box and change it so it resizes to 640, 480? Unless I misunderstand something, won't this allow a higher quality encoding than the suggested 640, 320? Since it is anamorphic, won't it still play back at the correct aspect ratio? Am I thinking wrong and there is no point in doing this or it will not work like I'm thinking?
Thanks in advance for your help.
You've cut 126 pixels of the 480 away. There are only about 314 left. Stretching that to 480 won't improve the image quality.
Thanks for the reply. A few minutes after I posted I got to thinking more and realized the answer and you have confirmed what I was thinking. I was over thinking things as usual.
anamorphic encoding without resizing
By hardy in forum Newbie / General discussionsReplies: 10Last Post: 18th Aug 2011, 16:38 -
MKV Anamorphic Problem Encoding In Handbrake...?
By Comfy in forum Video ConversionReplies: 5Last Post: 28th Dec 2010, 11:53 -
A few questions on Anamorphic encoding
By scubasam in forum Newbie / General discussionsReplies: 10Last Post: 31st Mar 2010, 22:04 -
Anamorphic encoding to 3gp container
By avreader1 in forum Video ConversionReplies: 2Last Post: 13th Mar 2010, 19:41 -
MeGUI - Clever Anamorphic Encoding?
By bullet_ballet in forum Newbie / General discussionsReplies: 1Last Post: 2nd Sep 2007, 23:29
