Hey, Im having a lot of trouble with the conversion of this video.
First of all, the original file is an mkv file, that is 18:50 in length.
ive tried MANY different converters, trying to convert it into MANY different types of files. I always got the same result, the converted file was only 9:27 for some reason. Not the full length.
I have no idea why this is happening. Ive even tried directly ripping the video portion from the file, and i still only got 9:27 length.
Does anyone know whats going on?
To help, this file is Episode 104 of Dragonball Z Remastered, it is the only episode that I have had this problem with, every other episode i have been able to convert without trouble.
Run the video through MediaInfo (tree view) and post a copy of the information here.
What converters have you tried? Have you tried using AVIDemux? Frameserving the MKV into VirtualDub using an AVIsynth script?
If you're using MKVExtractGUI with mkvtoolnix, do you have the latest versions of both, with both installed to the same directory?If cameras add ten pounds, why would people want to eat them? -
Yes, I have tried using AVIDemux. The strange thing about it is that, when I open the file on AVIDemux, its already cut in half. I can only edit up to 9:27, it acts as if thats the entire file.
I have V2.9.8 of MKVtoolnix, and no that did not work either.
I havent tried VirtualDub though, but other converters I have tried are the AnyVideo Converter, iPod converter, and PS3 Video 9 converter.
Also, here are the results from MediaInfo:
General
Complete name Dragonball_Z_104_-_Frieza_Defeated__.mkv
Format : Matroska
File size : 49.7 MiB
Duration : 18mn 50s
Overall bit rate : 369 Kbps
Encoded date : UTC 2007-10-28 14:30:16
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 13 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 18mn 49s
Nominal bit rate : 268 Kbps
Width : 720 pixels
Height : 384 pixels
Display aspect ratio : 1.875
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.040
Writing library : x264 core 56 svn-680
Encoding settings : cabac=1 / ref=10 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=268 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Audio #1
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : Yes
Format settings, PS : Yes
Codec ID : A_AAC
Duration : 18mn 50s
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Title : Original
Language : English
Audio #2
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 18mn 50s
Title : Funimation
Language : English
Audio #3
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 18mn 50s
Language : Japanese -
It's probably damaged or there's a glitch in the file at that exact time.
Does it play past 9:27 in a media player?
Why do you want to convert? It's pretty low bitrate to begin with. Converting it will make it worse -
Yes, it plays the entire video on media player.Originally Posted by poisondeathray
As for the conversion, I want to convert it because my PS3 can't play MKV files. So I want to convert it to an M2TS.
As for the bitrate, I dunno why its so low, the quality is actually fantastic
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 02:41 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 13:57 -
Will this cut my processing time in half?
By jsbenson in forum ComputerReplies: 7Last Post: 17th Oct 2009, 22:45 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
