First let me give some background:
I own a Samsung PN42B450 720p Plasma.
Now i know it's 720p but it is compatible with 1080p sources. So if i can get a higher resolution.... why not?
Also, i watch my movies off of my Xbox 360 in the Windows Media Center.
Now I'm using Xilisoft HD Video Converter.
It has Xbox360 profiles, but all of which help me none.
What i want, is a 5.1 audio, 1080p (1920 x 1024) video.
It seems no matter how much i change the FPS and the Bit rate i get this annoying stutter/lag during playback.
When playing a [720p / 2 channel / 23FPS / 4000bitrate] video file i converted using AVS 6, there is a little stutter/lag, but nothing like under xilisoft.
Even when i mimick those settings ^ i still get bad lag.
So, i come to you with my problem.
What can i do to stop the lag during playback?
Is it xilisoft?
Is it the resolution?
Thanks in advance,
Chris
(not sure if this is a video conversion thread topic or a newbie thread topic, feel free to remove if place in wrong section)
Closed Thread
lil_chris_chris, Do not post the same topic on several forums.
Please do not cross post, once is enough. If you wish a topic moved, PM a Moderator.
Continue in: https://forum.videohelp.com/topic375345.html#2021585
Moderator redwudz
x264, .mkv, 1080p movie not working on my tv
By PRiCK in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2012, 14:44 -
Help Converting 1080p x264 (.mkv)
By lil_chris_chris in forum Video ConversionReplies: 6Last Post: 10th Nov 2009, 08:49 -
Conversion of x264 High Profile 5.1 MKV 1080p to accomodate GPU
By cmwill3407 in forum Video ConversionReplies: 2Last Post: 27th Oct 2009, 23:18 -
problem playing mkv x264 1080p
By ioio in forum Software PlayingReplies: 24Last Post: 10th Oct 2009, 20:33 -
Having trouble with converting mkv to mp4 in 1080p
By NoobyDoo in forum Video ConversionReplies: 40Last Post: 17th Jun 2008, 23:59
