Hi,
I have raw avi file capture from DigiHi8 tap using Sony Handycam. This is captured during 2004 and before.
I need the following things to do.
1) I wanted to convert it to best video/audio quality format(may be like mpeg4 or etc.). I have Western Digital HD Video player where I can plug my external harddisk to play it).
2) I have my timestamp info in that captured avi and need to extract it and would like to add it as subtitile1.
Pls tell me which tools I can use of to do the above and which format would be suitable for the above.
I have 2 GB RAM and winXP. Attached is the avi file info.
Thanks in Advance.
Anbu.
Convert to mkv or mp4 with h264 video and aac audio using Handbrake.
Try extract the subtitle from the dv-avi using DV_Datecode, DV Sub Maker and then add the sub to the mkv using mkvtoolnix or mp4 using yamb. I'm not sure if a wd supports sub in mkv or mp4 though.
How do i convert .avi files to be playable on a dvd player?
By Beautiful Alone in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 04:03 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21 -
Convert from FCP output (DV-PAL) to a format playable on PC in WMP
By Ferry99 in forum Video ConversionReplies: 1Last Post: 24th Dec 2007, 19:32 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 17:53 -
WMV file to AVI playable on DVD player (motion is uneven when I try)
By lizzy1e in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2007, 15:13
