Title tells you exactly what I'm trying to do. I have installed x264vfw64 and the trial version of Vegas 9, but when I try to render, x264vfw64 is not one of the options. Any ideas how I can get it there? I only have 30 days, so I'd like to get the most out of it.
Thanks,
Dan
				Results 1 to 9 of 9
	Under the Render As -> Custom -> Video Tab -> Template options, I get the same list of choices that I get from the first Render As -> Template.
 I attempted to Google a solution, and came across a video. Immediately after the guy installed x264vfw, he ran Vegas, and the option was in the list under Render As -> Template.
	Can you link to the video ?
 Are you sure it's installed ? Do you see it in virtualdub, for example ?Read my blog here.
	Nolan s Veg 8.0 Rendering Tutorial - Part 1 It's a 3 video tutorial.
 I'm using the 64-bit version of Vegas, I had to install the 32-bit version of x264vfw to see it in VD, but I still don't see 32 or 64-bit in Vegas.
 I might just try installing 32-bit Vegas, and see if that works. I doubt I'll be doing anything to take advantage of using 64-bit.
	You could use a lossless intermediate exporting out of vegas (e.g. lagarith, huffyuv, UT), then and use x264 cli , or one of the GUI's for it e.g. xvid4psp, ripbot264, megui, handbrake
 You could even frameserve out of vegas with debugmode frameserver, but I'm not sure it works with the trial
 x264 is better, more stable, updated more frequently than x264vfw
  Cannot render to widescreen in neither vegas 7 or 8By 2prfm in forum Video ConversionReplies: 1Last Post: 7th Sep 2010, 09:38
  Vegas Batch Render?By duderdude2 in forum EditingReplies: 1Last Post: 28th Feb 2010, 03:42
  Vegas render questionBy wingfan in forum EditingReplies: 2Last Post: 29th Sep 2008, 20:10
  how do I batch render in vegas 7By Jorge in forum Video ConversionReplies: 1Last Post: 25th Aug 2007, 20:02
  Vegas Render Still SequenceBy vegasarian in forum Newbie / General discussionsReplies: 1Last Post: 4th Jun 2007, 08:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
