i want to get a laptop for light editing ...
how do these slow rpm laptops do?
can you really get any work done on them?
If you use TMpeg, as most people do for encoding, you can set the task priorities to low so you can actually get a lot of work done. I have a IBM laptop and I encode while doing many other things. I would suggest something with a strong CPU, as most of the video applications are CPU intensive. Memory doesn't seem to play a big role in encoding.
Cheers.-Ruinah69 -
Laptop hard drives are moving from 4200 rpm to 5400 rpm. The new ones also support ATA-100 transfer speeds, so whatever work you could do on a desktop with a 5400 rpm drive, you can probably do on one of the current generation laptops. Mobile CPUs mostly top out at 1.2 Ghz Pentium IIIs, but mobile Pentium 4s are on the way and mobile Athlons are available although they're not offered in many models.
If you don't expect a laptop to perform like a 2.2 Ghz Pentium 4 workstation with a 10000 rpm SCSI drive, it should handle your editing tasks with no problem. You can even get internal 8x or 16x (pricey) CD writers on them now to cut your VCDs or SVCDs. -
I have a 5400 RPM 20 gig drive and when using firewire it only drops one or 2 frames
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
laptop to tv
By halekon in forum DVB / IPTVReplies: 1Last Post: 13th Feb 2010, 16:29 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56
