I capture DV avi type I thru IEEE1394 by Ulead MSP6.5 in Win98SE system.
I wonder whether win2000 can solve the 4g limit.
Pls advise.
The 4Gig size limit is from file allocation tables. Win98 uses FAT32 which has the 4Gig limit. Win2000 uses either FAT32 or NTFS, WinXp uses either also. So if you want to get rid of the file limitation you need to use the NTFS. Which the following OS NT,2000 or XP.
I just loaded up a new system with Windows 2000 Pro...awesome! Win98SE is a joke compared to 2000 & XP. Trust me, if you upgrade, you'll wonder why you didn't do it a year ago. EVERYTHING loaded up with no problems, all drivers found, no errors, NO 98 BS to deal with. I am using Premiere to capture and can grab an hour of DV with no dropped frames, in one BIG capture. When you load up the OS, reformat the drives, follow the onscreen instructions and select NTFS (not FAT32) for you file system, this will cure the 4gb limit.
How do you like MSPro?? I have VS 5.0, but didn't bother loading it on this box. I really like Premiere so far for basic editing, fast & smooth, just getting cool titles & effects takes more work. I've heard MS pro is best for titling.
How do I get around the 5x change limit for DVD's
By trekker2u in forum Newbie / General discussionsReplies: 5Last Post: 1st Feb 2011, 01:25 -
Avermedia crazy limit
By Abas-Avara in forum Capturing and VCRReplies: 2Last Post: 19th Sep 2009, 13:03 -
Limit playback to first 20 seconds?
By jeff.mikolai in forum Video Streaming DownloadingReplies: 4Last Post: 20th Mar 2008, 16:47 -
****** You have reached your license limit.
By red-bull in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 4th Mar 2008, 05:23 -
What's the time limit on a DVD?
By PlayWithFire in forum Newbie / General discussionsReplies: 7Last Post: 22nd Nov 2007, 13:20
