Page 5 of 8
FirstFirst ... 3 4 5 6 7 ... LastLast
Results 121 to 150 of 217
  1. Well I already tried this and the sound is very quiet (Not normalized). Moreover it needs more time to convert doesnt it?
    Isnt there any way to make wavi.exe work? Some fixes?
    Jun 2005
    Portugal
    EAC3TO is faster, much faster
    there is an option available to normalize
    as for wavi the only way is to try in another computer, can't do anything about it because is external
  3. Okay thanks.
    But MKV2AC2 says that normalize isnt available for eac3to?!
    Jun 2005
    Portugal
    what version do you have ?
    you can normalize with EAC3TO, that option is available since version : MKV2AC3 Update - version 1.03.01 - Build 14/01/2011
    I don't know if that message appears in the last version, if it is ... well is just a small bug giving false information, forget it
  5. Im using v1.03.04 and I see a normalize checkbox. But it seems the sound is more quiet than the original
    Jun 2005
    Portugal
    if you are testing the results in your PC remember that your codecs should be well configured to decode AC3
    better is you take your MKV and test it in your TV or standalone player
  7. Okay Thanks
    I have one more question: Will there be the posibility to split the files into 4GB parts? Or do I need another program for this?
    Jun 2005
    Portugal
    Okay Thanks
    You can use MKVTOOLNIX that is part of MKV2AC3
    just load the resulting converted file
    menu Global -> enable splitting
    select your size and then Start Muxing
    The purpose of MKV2AC3 was to make a program as simple as possible, i.e., without many options, almost a one-click-solution for newbies or advanced users. Check the first post of this thread
  9. Hi (again) I thought your tool had FLAC support... I'm ALMOST possitive that EAC3TO supports it... WOuld you consider adding it to your tool?
    Thanks, and keep up the good work my man
    Jun 2005
    Portugal
    Hi,
    it is not officially supported but I just have converted a sample FLAC-MKV with eac3to and it works
    I have included some code in the program that manages that type of audio
    but as I said, it is not official but I left a door open in the code
    try it
    Jan 2013
    England
    Hi Delta2, Great program - thanks for developing it. Have used it a lot lately.
    However, am trying to convert a movie (MKV) and am getting
    ERROR ! check if you have a 64bit MKV2AC3 version. Conversion from string to type 'Integer' is not valid.
    So, I have downloaded and run the version in post #106 (above) and still the same error.
    So, being new to this stuff I downloaded the 64 bit version from the same post #106. Thinking maybe I do need the 64 bit version to convert this particular movies sound.
    Now though I get the error when I go to install, 'This installation package is not supported by this processor type. Contact your product vendor'.
    My Computer is a AMD Athlon 64 X2 Dual Core Processor. 5200+ 2.61gig. 2.75 gig Ram.
    Windows XP Pro Version 2002. Service Pack 2.
    Should it run fine (The 64 bit version) on this system ?
    Thanks for any help and sorry if the 64 bit thing is a daft question.
    Minnar
    Jun 2005
    Portugal
    uninstall completely the program and make a fresh install
    32 bits :
    https://www.videohelp.com/download/mkv2ac3_1_03_04_32bits.zip
    64 bits :
    https://www.videohelp.com/download/mkv2ac3_1_03_04_64bits.zip
    onde of them must work in your system
    Jan 2013
    England
    Thanks for the reply.
    As I said above - the 32 bit version works fine but, on the movie I am trying to convert at the moment, I get this .....
    That is the reason I was going to try the 64 bit version.
    So now, I have done as you suggest, trying to install the 64bit version I STILL get the error 'This installation package is not supported by this processor type. Contact your product vendor'.
    So if we go back to my original problem however, I am trying to convert a movie (MKV) and am getting
    I have just followed your above link and downloaded and installed the 32bit version again.
    Tried to covert the MKV file and I still get ........
    Any ideas ? Thanks for your advice
    Jun 2005
    Portugal
    put here a print-screen of the program with that error, I mean a print-screen where is visible the main program and the message box of that error
    Jan 2013
    England
    I hope this worked
    Jun 2005
    Portugal
    strange
    put in mediafire a sample of that movie
  17. Is it possible to have an option like:
    [x] Make destination folder the same as source folder
    I have around 200 movies I want to convert, but I want to keep them all on their respective folders
  18. Member
    Jan 2013
    England
    Delta2, I am taking down a sample for you right now. Also, does the info below help in the meantime ??
    Sample Included......: Yes
    DXVA Compliant.......: No
    Chapters Included....: No
    Source...............:
    Container............: MKV
    Length...............: 1 hour 54 minutes
    Size.................: 1.36 GiB
    Total Bitrate........: 1 718 Kbps
    IMDb Information.....: http://www.imdb.com/title/tt1649419/
    Genre................: Action | Drama | Thriller
    Codec................: AAC LC
    Bitrate..............: 165 Kbps
    kHz/bit..............: 48.0 KHz /
    Channels.............: 2
    Language.............: English
    Subtitles............: No
    Codec................: x264
    Type.................: DVDSCR
    Format Profile Level.: Main@L3.0
    Resolution...........: 720x304
    Aspect Ratio.........: 2.35:1
    Bitrate..............: 1 553 Kbps
    Framerate............: 23.976 FPS
    Jan 2013
    England
    Ok Delta2, This is strange, but I tried another download of the file and this time it converts without a problem.
    Obviously there was something slightly different about the first file, as the error messages show.
    Seems now that maybe the file is sometimes to blame ?
    Anyways, thanks for a great program and your help.
    Jun 2005
    Portugal
    Your problem is something due to mediainfo that couldn't retrieve correctly some info that movie
    If you look to the main folder of MKV2AC3 there is a file named MediaInfo.DLL
    I don't know the version of that file, maybe is old, you can update that file from here :
    http://mediainfo.sourceforge.net/en/Download/Windows
    You should select the DLL interface for the 64 bits version of Windows
    Jun 2005
    Portugal
    will see
  22. Any news on that , delta?
    Perhaps also add something like:
    [x] Overwrite source file
    So I wouldnt need to remove all the "_ac3" from the files..?
    THanks!
  23. Member
    Jun 2005
    Portugal
    I have had little time to see that
  24. I like this tool!
    I have some feature suggestions:
    1. Add some progressbars, because log is not very informative
    2. Allow window resize
  25. Member
    Mar 2013
    La Serena, Chile
    Hello Delta, I have nothing to say but thanks for your software, it has been very helpfull and it had save me lots of problems. However, I have an issue with one particular movie that I haven't could to convert it to AC3 with any of both methods MKV2AC3 allows.
    Whenever I try to convert it with aften method, after sometime of working it says that wavi.exe has stopped working and whener I try to convert it with eac3to it says: ERROR ! Try the other method of conversion.
    The mediainfo of the movie is this:
    General
    Unique ID : 233795956901335943609994231528721180790 (0xAFE376A32BD452EA9CA96B46412F6876)
    Complete name : D:\Peliculas\Zombieland\Zombieland.2009.1080p.BluR ay.DTS.x264.mkv
    Format : Matroska
    Format version : Version 2
    File size : 4.37 GiB
    Duration : 1h 27mn
    Overall bit rate : 7 141 Kbps
    Movie name : Zombieland.2009.1080p.BluRay.DTS.x264-RKO
    Encoded date : UTC 2010-01-23 04:43:07
    Writing application : mkvmerge v2.9.9 ('Tutu') built on Nov 25 2009 21:13:32
    Writing library : libebml v0.7.9 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 27mn
    Bit rate : 5 556 Kbps
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.151
    Stream size : 3.31 GiB (76%)
    Writing library : x264 core 77 r1294 813fe72
    Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=5556 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 1h 27mn
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 947 MiB (21%)
    Language : English
    Default : Yes
    Forced : No
    Audio #2
    Format : Vorbis
    Format settings, Floor : 1
    Codec ID : A_VORBIS
    Duration : 1h 27mn
    Bit rate mode : Variable
    Bit rate : 80.0 Kbps
    Channel(s) : 2 channels
    Stream size : 50.2 MiB (1%)
    Title : Commentary
    Writing library : aoTuV b5c (UTC 2008-12-15)
    Language : English
    Default : No
    Forced : No
    Text
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Language : English
    Default : Yes
    Forced : No
    Any suggestion?. Hope that this info helps to solve the problem.
    Thanks in advance
  26. Member
    May 2010
    Dunedin, New Zealand
    Hello!
    Firstly, thank you so much for the fantastic tool.
    I have one problem, and I have searched for it so I wouldn't be going over old ground, but I cannot find it anywhere - which is odd.
    Regardless of the original - or source format, and regardless of their bit-rate, I cannot configure the 6 channel AC3 output to be anything other than 448 Kbps. Regardless of whether I want it a lower rate, or a larger rate. The 'AC3 normalize' function makes no difference - and given the (usually fantastic) simplicity of the interface, there is simply no way to fiddle with variables.
    Can anybody help with this?
    Dodgy version, perhaps?
    Thanks very much,
    Simon J
  27. Member
    Jun 2005
    Portugal
    Thanks in advance
    Can you put a sample in mediafire ?
  28. Member
    Jun 2005
    Portugal
    Originally Posted by cinesimon View Post
    Hello!
    Thanks very much,
    Simon J
    you're saying that you can't set a lower bitrate or higher ?
    Which method do you use ?
  29. Member
    May 2010
    Hi Delta2 - this happens with both aften and eac3to.
  30. Member
    May 2011
    Hello: I did not look at this thread completely but I did look at the file your having problems with and here is what I would do with it..First I would run it through the newest version mkvtoolnix/mkvmerge and uncheck the vorbis soundtrack and just let mkvmerge rewrite the file it takes a minute or so,,the file you have left will just contain the video,dts,and subtitle text..Then I would run that file through Mkv2ac3 as you normally do..Once in a while mkv2ac3 has trouble with audio Ids,,if they are not there then the problem dissapears..All im ever concerned with is converting the dts file to ac3...If this fails then I rencode the whole file to an mkv/1024X576/ac3/6 file using theTX264 encoder or just dump the whole file and look for a different one..I hope this helps you and good luck...~
