Hi, i have a Leadtek WinFast 2000XP Expert Video capture card and was wondering if i could capture video using the Hauppauge WinTV software, instead of the winfast software that it came with.
Is it possible to do this?
Can a pci capture/video card work with another brand of capture software?
Thanks.![]()
Yes.... Not sure about the Hauppauge Software though...Try ItOriginally Posted by VEBouto
Hauppauge HDTV tuner card set-up question
By tinpanalley in forum DVB / IPTVReplies: 2Last Post: 2nd Apr 2012, 08:11 -
Just installed hauppauge 2250 dual tunser viseo card need some help & info
By case310350 in forum Capturing and VCRReplies: 1Last Post: 12th Mar 2011, 11:47 -
Hauppauge PVR-250 software question
By Ogilvy in forum Capturing and VCRReplies: 19Last Post: 28th Sep 2010, 03:11 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 08:35 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 14:49
