Anybody know if there's a way to install cce as a plugin for flask, similar to how lsx or the panasonic encoderz can be installed as plugins? i think there's a way to do it with premiere.
Would frameserving directly from flask to cce work, anyone have problems with this setup?
Thanx again
Zooter
When you install cce, it will ask you, whether you want to install it as standalone or Premiere plugin. Just choose plugin version and install it to the Adobe Premiere plugin subdirectory. Rename it like you would rename the other plugins. That's all.
FlasK> cce plugin might work for CBR encodes, but for VBR use DVD2Avi>Avisynth(Vdub)>cce(standalone) -
tru,
know what, i tried that with premiere 6 and then renaming it to the flask (0.6) folder but it didnt pick it up.
I searched the forum, and i think it may work with an older version. I ll stick to the avisynth way i think.
Thanx, appreciate it. It would've just made it a bit easier.
oh well, u win some , u Fserve some..
ZtR
Help please with Aiseesoft trim function,
By cromwell in forum Newbie / General discussionsReplies: 10Last Post: 16th May 2013, 07:50 -
Comment on Search Function
By smartel in forum FeedbackReplies: 4Last Post: 21st Jun 2011, 05:53 -
Need slave function for capturing
By doggyjumper in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 12:06 -
Resume function
By powersmo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th May 2008, 12:59 -
DVDShrink Incorrect Function
By pablo1999 in forum Authoring (DVD)Replies: 1Last Post: 25th Jun 2007, 13:42
